Garuda team,
I have a small feature request about the theming of your GNOME distribution. Whenever I use the search feature, I am unable to tell visually which item is selected. I have not modified my theme from the default prodided.
See attached YouTube video issue reproduction.
If it could be patched so it is possible to visually tell which item is selected, I'd greatly appreciate it!
Thanks so much for all your work on this project! This is a great distro on so many levels!
Here's my specs for good measure
inxi -Faz
System: Kernel: 5.14.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e4c4926c-4152-45f4-90fa-b2332fd25368
systemd.unified_cgroup_hierarchy=1 resume=UUID=b966e007-7b72-4bfa-9db7-8018c3cbb4dd loglevel=3
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: Micro-Star product: GT76 Titan DT 9SF v: REV:1.0 serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Micro-Star model: MS-17H1 v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E17H1IMS.10D date: 05/19/2020
Battery: ID-1: BAT1 charge: 82.2 Wh (100.0%) condition: 82.2/90.0 Wh (91.3%) volts: 16.6 min: 14.4
model: MSI BIF0_9 type: Li-ion serial: N/A status: Full
CPU: Info: 8-Core model: Intel Core i7-9700K bits: 64 type: MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: D (13) microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57600
Speed: 4650 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 4650 2: 3974 3: 4600 4: 4688
5: 4613 6: 4691 7: 4563 8: 4583
Graphics: Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e98 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Micro-Star MSI driver: nvidia
v: 470.74 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f10 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: modesetting,nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 5760x1354 s-dpi: 96 s-size: 1524x358mm (60.0x14.1") s-diag: 1565mm (61.6")
Monitor-1: eDP-1 res: 1920x1080 dpi: 128 size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
Monitor-2: DP-1-2.1 res: 1920x1080 hz: 60 dpi: 80 size: 609x349mm (24.0x13.7")
diag: 702mm (27.6")
Monitor-3: DP-1-2.2 res: 1920x1080 hz: 60 dpi: 80 size: 609x349mm (24.0x13.7")
diag: 702mm (27.6")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Realtek USB Audio type: USB driver: snd-usb-audio bus-ID: 5-1.5:4 chip-ID: 0bda:4014
Sound Server-1: ALSA v: k5.14.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000
bus-ID: 3d:00.0 chip-ID: 10ec:3000 class-ID: 0200
IF: enp61s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™ driver: iwlwifi v: kernel
port: 3000 bus-ID: 3e:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp62s0 state: up mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 6-1.2:3
IF: enp12s0u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 8087:0029 class-ID: e001
Drives: Local Storage: total: 2.75 TiB used: 109.15 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:10 vendor: Samsung model: MZVLW256HEHP-00000 size: 238.47 GiB
rev: CXB7401Q temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000 size: 476.94 GiB
rev: EXA7301Q temp: 36.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Samsung model: MZVPW256HEGL-00000 size: 238.47 GiB
rev: CXZ7500Q temp: 40.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174 size: 1.82 TiB
serial: <filter> rev: SDM1 scheme: GPT
Partition: ID-1: / raw-size: 203.86 GiB size: 203.86 GiB (100.00%) used: 109.15 GiB (53.5%) fs: btrfs
dev: /dev/nvme2n1p2 maj-min: 259:8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 563 KiB (0.2%) fs: vfat
dev: /dev/nvme2n1p1 maj-min: 259:7
ID-3: /home raw-size: 203.86 GiB size: 203.86 GiB (100.00%) used: 109.15 GiB (53.5%) fs: btrfs
ID-4: /var/log raw-size: 203.86 GiB size: 203.86 GiB (100.00%) used: 109.15 GiB (53.5%)
fs: btrfs dev: /dev/nvme2n1p2 maj-min: 259:8
ID-5: /var/tmp raw-size: 203.86 GiB size: 203.86 GiB (100.00%) used: 109.15 GiB (53.5%)
ID-1: swap-1 type: partition size: 34.35 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme2n1p3 maj-min: 259:9
ID-2: swap-2 type: zram size: 31.22 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 74.0 C mobo: 27.8 C
Info: Processes: 330 Uptime: 36m wakeups: 3 Memory: 31.22 GiB used: 4.4 GiB (14.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1279 lib: 327
Shell: fish v: 3.3.1 running-in: gnome-terminal inxi: 3.3.06
