Hey all,
I’ve somehow mucked up my Gnome Terminal default by trying to install some additional themes, and now it’s not using the Garuda profile from the terminal anymore. The Garuda profile has also disappeared from the list of profiles to choose from. Is there anyway I can reset the Gnome Terminal to defaults to use the Garuda profile? Trying to avoid a fresh reinstall as I have a lot of work on this PC. Below is my garuda-inxi
. I’ve tried searching for similar issues, and searched through Nautilus for the config file to use until I’m blue in the face.
root=UUID=a4c56bc9-0f01-4564-8dda-2d4fa6731708 rw rootflags=subvol=@
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX516PM_FX516PM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX516PM v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: FX516PM.330 date: 05/15/2023
ID-1: BAT0 charge: 56.4 Wh (99.1%) condition: 56.9/76.0 Wh (74.9%)
power: 2.9 W volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging cycles: 336
Info: model: 11th Gen Intel Core i7-11370H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0xAC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1624 high: 3882 min/max: 400/4800 base/boost: 3300/4800
scaling: driver: intel_pstate governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 3299 2: 2212 3: 2002 4: 400 5: 3882 6: 400
7: 400 8: 400 bogomips: 52838
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-3,DP-5 off: eDP-1 empty: DP-1, DP-2, DP-4, DP-6,
HDMI-A-2 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 545.xx+ status: current (as of 2023-10;
EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 ports: active: none empty: HDMI-A-1 bus-ID: 0000:01:00.0
chip-ID: 10de:2520 class-ID: 0300
Display: server: X.Org v: 23.2.2 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1355x381mm (53.35x15.00")
s-diag: 1408mm (55.42")
Monitor-1: DP-3 pos: primary,left res: 2560x1440 hz: 75 dpi: 123
size: 530x300mm (20.87x11.81") diag: 609mm (23.98") modes: N/A
Monitor-2: DP-5 pos: right res: 2560x1440 hz: 75 dpi: 123
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
Server-1: PipeWire v: 0.3.84 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:2e:00.0
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 35.93 GiB (2.6%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731030WD temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung
fw-rev: FXM7201Q temp: 38.9 C scheme: GPT
used: 35.93 GiB (7.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:7
used: 580 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:6
maj-min: 259:7
maj-min: 259:7
maj-min: 259:7
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2200
Processes: 311 Uptime: 0m wakeups: 0 Memory: total: 16 GiB
available: 15.32 GiB used: 3.06 GiB (20.0%) igpu: 64 MiB Init: systemd
v: 254 default: graphical tool: systemctl Compilers: gcc: 13.2.1
clang: 16.0.6 Packages: pm: pacman pkgs: 1687 libs: 449
tools: gnome-software,pamac,paru pm: flatpak pkgs: 0
Shell: garuda-inxi (sudo) default: Bash v: 5.2.15 running-in: gnome-terminal
inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-10-24
Last full system update: 2023-11-03
Windows dual boot: Yes
