Gnome Software application, the explore section does not load
In the Gnome Software application, the explore section does not load.
I just started using Linux and I don’t know much about it. How do I fix this problem?
And I’m currently using arch.
I formatted the system twice and installed Garuda Gnome, but it still didn’t work.
If the issue occurs in both Arch and Garuda, it means that it is not a Garuda problem.
Good to see that you asked in the Gnome forum.
Maybe also a bug report upstream would be better.
It could be a configuration problem (I’m not a Gnome user, so cannot help much) or an issue, maybe this:
I struggled a bit. I tried a lot of commands, I didn’t understand exactly how I fixed it, but I fixed it with chatgpt. Thank you again :smiley:
