Gnome extensions not working
Hello Garuda users.
I try to install a gnome extension with gnome-shell-extension, gnome-browser-connector and the firefox/chrome addon. In firefox I get the error "An unexpected error occurred" directly above the installation button. I don't need to press the button, to generate this error. This there with the page load.
In chrome I get the error "Native host has exited." when loading a page.
How to fix this?
  Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=d85f77c8-a79c-4332-93bc-9651115467ce rw rootflags=subvol=@
    quiet rd.luks.uuid=e3dd4811-0d6c-401f-ac07-de6876a4034d quiet splash
    rd.luks.uuid=89bf6be2-3e78-4754-826f-17586e9447b5
    resume=/dev/mapper/luks-89bf6be2-3e78-4754-826f-17586e9447b5 loglevel=3
  Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
  Type: Laptop System: Microsoft product: Surface Pro
    v: 124000000000000000000000D:0B:2EF:5C:09P:38S:01E:0
  Mobo: Microsoft model: Surface Pro serial: <superuser required>
    UEFI: Microsoft v: 235.3261.768 date: 05.29.2020
  ID-1: BAT1 charge: 38.6 Wh (100.0%) condition: 38.6/45.0 Wh (85.8%)
    volts: 8.7 min: 7.6 model: DYN M1009168 type: Li-ion serial: <filter>
    status: full cycles: 80
  Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1132 high: 2700 min/max: 400/3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 610 2: 619 3: 2700 4: 600
    bogomips: 21599
  Device-1: Intel HD Graphics 620 vendor: Microsoft driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-3,eDP-1
    empty: DP-1, DP-2, DP-4, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: DP-3 model: LG (GoldStar) 24MB37 serial: <filter> built: 2019
    res: 1920x1080 dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42")
    diag: 587mm (23.1") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 model: LG Display 0x0555 serial: <filter> built: 2016
    res: 2736x1824 dpi: 267 gamma: 1.2 size: 260x173mm (10.24x6.81")
    diag: 312mm (12.3") ratio: 3:2 modes: 2736x1824
  Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
  Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
    Unit driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0
    chip-ID: 8086:1919 class-ID: 0480
  Device-2: Intel CSI-2 Host driver: N/A alternate: ipu3_cio2
    bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
  Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
  API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api tools: N/A
  Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
    v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
    chip-ID: 11ab:2b38 class-ID: 0200
  Device-2: Microsoft RTL8153 GigE [Surface Ethernet Adapter] type: USB
    driver: r8152 bus-ID: 2-3.2:5 chip-ID: 045e:07c6 class-ID: 0000
  IF: enp0s20f0u3u2 state: down mac: <filter>
  IF-ID-1: br-3dab1c22d8bd state: down mac: <filter>
  IF-ID-3: wwp0s20f0u2 state: down mac: <filter>
  Device-1: Marvell Bluetooth and Wireless LAN Composite type: USB
    driver: btusb v: 0.8 bus-ID: 1-5:7 chip-ID: 1286:204c class-ID: e001
  Local Storage: total: 238.47 GiB used: 12.55 GiB (5.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: KUS030202M-B000
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
    lanes: 2 type: SSD serial: <filter> rev: DXY8AM1Q temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
    used: 12.55 GiB (5.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-e3dd4811-0d6c-401f-ac07-de6876a4034d
  ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-89bf6be2-3e78-4754-826f-17586e9447b5
  ID-2: swap-2 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 32.0 C pch: 27.0 C mobo: N/A
  Processes: 308 Uptime: 2h 12m wakeups: 4 Memory: 7.68 GiB
  used: 3.38 GiB (44.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1122
  libs: 340 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.26
  System install date:     2023-05-04
  Last full system update: 2023-05-05 ↻
How to fix Native Host Has Exited error in Chrome browser extension
stackoverflow.com › questions › how-to-fix-native-…
(https://stackoverflow.com/questions/27785153/how-to-fix-native-host-has-exited-error-in-chrome-browser-extension-native-me)
Happened to me on Linux (RHEL 7.6). To find the root cause, you’ll need run your chrome from console (command line), and open the gnome …
journalctl --user -xe gives anything related? Is this a Python package by chance?
Edit: yep
depends=(gnome-shell python-gobject)
I'd propose a full system update & relog (just did a rebuild on the repo side)
thanks. It works now
