Gnome-control-centre 47.2-1 not opening
Sir/Madam,
Gnome-control-centre 47.2-1 not opening . Not able add/modify to gmail account, which can sync to calendar. Please help me to resolve the issue.
Thanks,
 → garuda-inxi
  Kernel: 6.6.63-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=21552d5d-e026-4b4a-a2a8-ab97d6cbccde rw rootflags=subvol=@
    resume=UUID=e7acc7cd-2fe2-4482-b401-85fb5ef12388 quiet
    resume=UUID=e7acc7cd-2fe2-4482-b401-85fb5ef12388 loglevel=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: albert,xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
  Type: Desktop System: Dell product: OptiPlex 7020 v: 01
    serial: <superuser required> Chassis: type: 15 serial: <superuser required>
  Mobo: Dell model: 02YYK5 v: A01 serial: <superuser required>
    part-nu: OptiPlex 7020 uuid: <superuser required> BIOS: Dell v: A04
    date: 04/01/2015
  Info: model: Intel Core i3-4160 bits: 64 type: MT MCP arch: Haswell
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 3592 min/max: 800/3600 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 3592 2: 3592 3: 3592 4: 3592 bogomips: 28740
  Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
    vendor: Dell driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
    built: 2013 ports: active: HDMI-A-1 empty: DP-1, DP-2, HDMI-A-2, VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:041e class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: xfwm4 v: 4.18.0 driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :0.0
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Lenovo LEN L27i-28
    serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
  API: Vulkan v: 1.3.295 layers: 6 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4400 (HSW GT2) driver: mesa intel v: 24.3.1-arch1.1
    device-ID: 8086:041e surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.3.1-arch1.1 (LLVM
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  API: ALSA v: k6.6.63-1-lts status: kernel-api tools: N/A
  Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
    port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  IF-ID-1: br-ea45ab4dcfe7 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-3: vethf18bd79 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-4: virbr0 state: down mac: <filter>
  Info: services: httpd, NetworkManager, smbd, sshd, systemd-timesyncd,
    wpa_supplicant
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3:3 chip-ID: 2357:0604
  Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
  Local Storage: total: 4.55 TiB used: 1.3 TiB (28.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 043 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
  ID-1: / raw-size: 920.08 GiB size: 920.08 GiB (100.00%)
    used: 247.91 GiB (26.9%) fs: btrfs block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1
  ID-2: /home raw-size: 920.08 GiB size: 920.08 GiB (100.00%)
    maj-min: 8:1
  ID-3: /var/log raw-size: 920.08 GiB size: 920.08 GiB (100.00%)
    maj-min: 8:1
  ID-4: /var/tmp raw-size: 920.08 GiB size: 920.08 GiB (100.00%)
    maj-min: 8:1
  ID-2: swap-2 type: partition size: 11.43 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 49.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.53 GiB used: 4.12 GiB (26.5%)
  Processes: 314 Power: uptime: 12m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: upowerd,xfce4-power-manager
  Packages: 2105 pm: pacman pkgs: 2037 libs: 500
    tools: octopi,pamac,paru,yay pm: flatpak pkgs: 68 Compilers: clang: 18.1.8
    gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
    running-in: xfce4-terminal inxi: 3.3.36
  System install date:     2024-09-14
  Last full system update: 2024-12-06 ↻
  Failed units:            calibre-server.service
You realize you tagged a GNOME issue to an XFCE channel.
I can only tell you to look for something different that can do the same thing, Things built for Gnome are sometimes designed never to work out of it.
If its a calender and email sync you wan’t, have you thought about Thunderbird.
