Hello Garuda users.
I'm in trouble with gnome settings after the upgrading to 44.
I'm currently on Gnome/Wayland. Same on Xorg.
I can't open anymore gnome-control-center from either cli or from gui: fun fact no stout and sterr were reported:
λ gnome-control-center -v
λ gnome-control-center -v 2| tee gnome.log
even system logs (dmesg and journalctl) don't report anything:
May 10 12:45:18 ceccaruda gnome-shell[15979]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x100000b
May 10 12:45:41 ceccaruda systemd[15640]: Started Application launched by gnome-shell.
May 10 12:46:05 ceccaruda systemd[15640]: Started Application launched by gsd-media-keys.
May 10 12:46:05 ceccaruda gnome-shell[15979]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x100000b
May 10 12:46:58 ceccaruda guake.desktop[16399]: Current link under cursor: None
May 10 12:46:58 ceccaruda guake.desktop[16399]: Current filename under cursor: None
May 10 12:46:58 ceccaruda guake.desktop[16399]: Custom file does not exit: /home/cecca/.config/guake/custom_command.json
May 10 12:47:14 ceccaruda systemd[15640]: Started Application launched by gsd-media-keys.
Any idea about how to start to solve this problem?
Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 13.1.1
root=UUID=3387fe52-e8cb-45c6-87fb-f4e8ea30cb2c rw
[email protected] acpi_backlight=vendor
pcie_aspm=force
cryptdevice=UUID=551e16bb-03e7-4bf4-83c3-40579df2ea66:luks-551e16bb-03e7-4bf4-83c3-40579df2ea66
root=/dev/mapper/luks-551e16bb-03e7-4bf4-83c3-40579df2ea66
psi=1 rd.udev.log_priority=3
vt.global_cursor_default=0
resume=/dev/mapper/luks-fbbf49a3-e58e-445b-a8bd-e1860d39b5f6
loglevel=3 rcutree.rcu_idle_gp_delay=1
nvidia_drm.modeset=1 ibt=off
Desktop: Unity wm: gnome-shell dm: 1: GDM v: 44.1
2: LightDM v: 1.32.0 note: stopped Distro: Garuda Linux
Type: Laptop System: LENOVO product: 20202
v: Lenovo IdeaPad Z500 serial: <superuser required>
Chassis: type: 10 v: Lenovo IdeaPad Z500
Mobo: LENOVO model: INVALID v: 31900003WIN8 STD MLT
serial: <superuser required> UEFI: LENOVO
v: 71CN52WW(V1.22) date: 01/24/2013
ID-1: BAT1 charge: 7.0 Wh (25.8%)
condition: 27.1/26.6 Wh (101.8%) volts: 14.7 min: 14.8
model: LENOVO PABAS0241231 type: Li-ion
Info: model: Intel Core i7-3632QM bits: 64 type: MT MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15
process: Intel 22nm family: 6 model-id: 0x3A (58)
stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8
smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2909 high: 3200 min/max: 1200/3200
scaling: driver: intel_cpufreq governor: performance
cores: 1: 2421 2: 3200 3: 3200 4: 1829 5: 3200
6: 3200 7: 3200 8: 3026 bogomips: 35119
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2
ssse3 vmx
Device-1: Intel 3rd Gen Core processor Graphics
vendor: Lenovo driver: i915 v: kernel arch: Gen-7
process: Intel 22nm built: 2012-13 ports:
active: HDMI-A-1,LVDS-1 empty: DP-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Lenovo EasyCamera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-4:2 chip-ID: 04f2:b35d class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8
with: Xwayland v: 23.1.1 compositor: gnome-shell
driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915
display-ID: 0
Monitor-1: HDMI-A-1 model: BenQ GW2780
serial: <filter> built: 2022 res: 1920x1080 dpi: 82
gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080
min: 720x400
Monitor-2: LVDS-1 model: LG Display 0x03d6
built: 2012 res: 1366x768 dpi: 101 gamma: 1.2
size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.2 Mesa 23.0.3 renderer: Mesa Intel
HD Graphics 4000 (IVB GT2) direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition
Audio vendor: Lenovo 7 driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api
tools: N/A
Server-1: sndiod v: N/A status: off
tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 0.3.70 status: active with:
1: pipewire-pulse status: active 2: wireplumber
status: active 3: pipewire-alsa type: plugin
4: pw-jack type: plugin
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
Device-2: Intel Centrino Wireless-N 2230
driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0888
Device-1: Intel Centrino Bluetooth Wireless Transceiver
driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1.3:5 chip-ID: 8087:07da
Report: bt-adapter ID: hci0 rfk-id: 2 state: up
address: <filter>
Local Storage: total: 1.82 TiB used: 395.12 GiB (21.2%)
SMART Message: Required tool smartctl not installed.
Check --recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung
model: SSD 860 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate
model: ST1000LM014-1EJ164 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: LVD1
ID-1: / raw-size: 922.46 GiB size: 922.46 GiB (100.00%)
used: 395.08 GiB (42.8%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0
mapped: luks-551e16bb-03e7-4bf4-83c3-40579df2ea66
ID-2: /boot/efi raw-size: 256 MiB
size: 252 MiB (98.46%) used: 44.1 MiB (17.5%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.46 GiB
size: 922.46 GiB (100.00%) used: 395.08 GiB (42.8%)
ID-4: /var/log raw-size: 922.46 GiB
ID-5: /var/tmp raw-size: 922.46 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 7.62 GiB
used: 2.32 GiB (30.4%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
maj-min: 254:1
mapped: luks-fbbf49a3-e58e-445b-a8bd-e1860d39b5f6
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 349 Uptime: 42m wakeups: 1 Memory:
available: 7.62 GiB used: 3.69 GiB (48.5%)
Init: systemd v: 253 default: graphical tool: systemctl
Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1811
pm: pacman pkgs: 1802 libs: 452
tools: gnome-software,pamac,paru pm: flatpak pkgs: 9
Shell: fish v: 3.6.1 running-in: tmux: inxi: 3.3.27
System install date: 2021-06-04
Last full system update: 2023-05-09
Relevant software: timeshift NetworkManager dracut
Failed units: shadow.service
Greetings!
Fil
