Hi! I just upgraded my GPU from an RX 5600 XT to a RX 7900 XTX. I use a single 48" LG C1 OLED TV, and I'm running GNOME. I'm currently running into issues where the colors appear drab and muted after the hardware upgrade. I've had this issue before, but usually resolved it using my LG TV's color settings. I even tried "game mode", which is helpful, but not helpful enough to make the colors match what I expect to see. Nothing I'm trying this time helps very much at all, so I'm wondering if there's a software issue of some kind. I also found it helps to not run the display at 120 Hz, otherwise that results in weird coloring around text characters antialiasing. I'm using HDMI, with a proper HDMI 2.1 cable, but I can't use DP since it's technically a TV. I've been an Arch user for over a decade, but I'm new to troubleshooting these kinds of issues, so I'm not quite sure where to start or what to try. halp? ![]()
Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ae8b0b9d-1bbf-40b4-be29-a7758013bb1b rw rootflags=subvol=@
quiet
cryptdevice=UUID=8573d123-3b45-4695-8f01-280827fd4978:luks-8573d123-3b45-4695-8f01-280827fd4978
root=/dev/mapper/luks-8573d123-3b45-4695-8f01-280827fd4978 quiet splash
resume=/dev/mapper/luks-dc3ce9e4-f899-4fbc-94b3-bd8b8716eef4 loglevel=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: Micro-Star model: MEG X570 GODLIKE (MS-7C34) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.C0
date: 02/02/2021
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3424 high: 3982 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3602 11: 3400
12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400
20: 3400 21: 3400 22: 3400 23: 3400 24: 3400 25: 3982 26: 3400 27: 3400
28: 3400 29: 3400 30: 3400 31: 3400 32: 3400 bogomips: 217620
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 2f:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4.3:6 chip-ID: 046d:085c
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) TV SSCR
serial: <filter> built: 2021 res: 3840x2160 dpi: 61 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 7900 XTX (gfx1100
LLVM 15.0.7 DRM 3.49 6.2.2-zen1-1-zen) direct-render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel pcie: bus-ID: 1-1.4.3:6
chip-ID: 046d:085c gen: 4 speed: 16 GT/s class-ID: 0102 lanes: 16
serial: <filter> bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: Audient EVO4 type: USB driver: snd-usb-audio bus-ID: 1-2:3
chip-ID: 2708:0006 class-ID: fe01
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
Device-1: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Micro-Star MSI driver: N/A modules: atlantic pcie: gen: 3
speed: 8 GT/s lanes: 4 port: N/A bus-ID: 24:00.0 chip-ID: 1d6a:07b1
Device-2: Realtek vendor: Micro-Star MSI driver: N/A modules: r8169 pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 1000
bus-ID: 26:00.0 chip-ID: 10ec:2600 class-ID: 0200
Device-3: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: N/A
modules: r8169 pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 2000
bus-ID: 27:00.0 chip-ID: 10ec:3000 class-ID: 0200
Device-4: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™ driver: N/A
modules: iwlwifi pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 28:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-5: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-3.2:5 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp49s0f3u3u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 8.99 TiB used: 4.09 TiB (45.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 Plus
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: R4PB47.2 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-3: /dev/sdb maj-min: 8:16 vendor: Micron model: 5100 EEFDDAK3T8TCB
size: 3.49 TiB block-size: physical: 8192 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0369 scheme: GPT
ID-1: / raw-size: 3.5 TiB size: 3.5 TiB (100.00%) used: 1.16 TiB (33.2%)
mapped: luks-8573d123-3b45-4695-8f01-280827fd4978
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 3.5 TiB size: 3.5 TiB (100.00%)
used: 1.16 TiB (33.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 3.5 TiB size: 3.5 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.5 TiB size: 3.5 TiB (100.00%)
ID-1: swap-1 type: zram size: 125.71 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 138.28 GiB used: 0 KiB (0.0%)
mapped: luks-dc3ce9e4-f899-4fbc-94b3-bd8b8716eef4
System Temperatures: cpu: 44.4 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 65.0 C
Processes: 577 Uptime: 20m wakeups: 0 Memory: 125.71 GiB
used: 9.14 GiB (7.3%) Init: systemd v: 253 default: graphical
pkgs: 1699 libs: 521 tools: gnome-software,pamac,paru,yay pm: flatpak
pkgs: 0 Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-01
Last full system update: 2023-03-06
Failed units: nmb.service
