The issue still exists if I remove the workaround:
set
WaylandEnable=false
in/etc/gdm/custom.conf
set
WaylandEnable=false
So it's a Wayland-issue.
Do you use Wayland on Gnome itself? Does that work?
nope, I had both of them.
But I donât think it will work by using Wayland only, removing Xorg.
Okay, but do you have an Nvidia GPU? I see no garuda-inxi to work with here.
Hereâs my inxi, thank you for your help!
⯠garuda-inxi
Kernel: 6.0.7-1-cachyos arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=974f3ce6-ba35-41c5-a737-23cb1e2b873f rw rootflags=subvol=@
lsm=landlock,lockdown,yama,integrity,apparmor,bpf quiet splash
mitigations=off rd.udev.log_priority=3 vt.global_cursor_default=0
loglevel=3 amd_pstate.epp=1
Desktop: GNOME v: 43.0 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Acer product: Swift SF314-43 v: V1.04
Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required>
UEFI: Insyde v: 1.04 date: 07/28/2021
ID-1: BAT1 charge: 12.5 Wh (24.9%) condition: 50.2/53.2 Wh (94.4%)
volts: 10.6 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7
(7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 566 high: 1397 min/max: 400/4056 scaling:
driver: amd_pstate_epp governor: powersave cores: 1: 1397 2: 400 3: 400
4: 400 5: 400 6: 400 7: 1397 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 50358
Type: retbleed status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:164c class-ID: 0300 temp: 43.0 C
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 0408:a094 class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: eDP-1 model: AU Optronics 0x683d built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
OpenGL: renderer: AMD Radeon Graphics (renoir LLVM 14.0.6 DRM 3.48
6.0.7-1-cachyos) v: 4.6 Mesa 22.2.2 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Acer Incorporated
ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Acer Incorporated
ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.0.7-1-cachyos running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: enp3s0f3u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Device-1: Lite-On Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:4 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 46.53 GiB (9.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFK0S03
temp: 55.9 C scheme: GPT
ID-1: / raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 16.95 GiB
(26.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%) used: 308 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 64 GiB size: 64 GiB (100.00%) used: 8.1 GiB (12.7%)
ID-4: /var/log raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 16.95
GiB (26.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 16.95
ID-1: swap-1 type: zram size: 7.12 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.4 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 392 Uptime: 2m wakeups: 46 Memory: 7.12 GiB used: 3.32 GiB
(46.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 1411 pm: pacman pkgs: 1377 libs: 358
tools: gnome-software,pamac,paru pm: flatpak pkgs: 28 pm: snap pkgs: 6
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-11-03
Last full system update: 2022-11-04
maybe an amd equivalent of intel-media-driver
may work?
Iâm not sure where youâre getting the idea youâre using anything Intel here, because youâre not. AMD CPU, AMD Vega GPU built-in to the CPU.
Iâm using an AMD RX 6700 XT with my desktop, and GDM is working in Wayland, but I donât use Wayland actual for my session. Xorg is what I use still due to compatability with things I use still doesnât work with Wayand yet. That said though, I tested it with Wayland and it works fine on amd and intel GPUs.
A log of gdm might be useful to help figure out whatâs going on if itâs not working.
The new gnome 43.1 update has fixed the issue for me too!
Thanks for your time and help!
