Recently upgraded to KDE6 and spent the better part of the last few hours trying to get everything set up the way I had it before. Try as I might, I cannot get the Konsole terminal glyphs to appear as they once did. (See the “square” icons in the attached screenshot for what I mean).
Tried using nerdfix on starship.toml as suggested elsewhere but that had no effect. Any ideas where to start looking would be helpful. Googling and forum-searching hasn’t turned up anything that’s relevant to me. Also the glyphs appear to work in Alacritty, but not in Konsole.
I’m on stock Dr460nized by the way
garuda-inxi:
Kernel: 6.8.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bb56b6c6-cca3-4ece-83fc-02bd3975f545 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=6244d32d-2c70-477c-af93-53438cff4ad5 loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: MEG Z490I UNIFY (MS-7C77) v: 1.2
serial: <superuser required> part-nu: B926.C uuid: <superuser required>
UEFI: American Megatrends v: C.40 date: 07/22/2020
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xFA
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1325 high: 5000 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 5000 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 5000 bogomips: 121596
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:9bc5 class-ID: 0380
Device-2: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-3
empty: DP-4,DP-5,HDMI-A-4 bus-ID: 01:00.0 chip-ID: 10de:1e84
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
alternate: fbdev,intel,nv,vesa dri: iris gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 2560x1080 s-dpi: 92 s-size: 707x301mm (27.83x11.85")
s-diag: 768mm (30.25")
Monitor-1: DP-3 mapped: DP-0 note: disabled model: MSI MAG301CR
built: 2020 res: 2560x1080 hz: 200 dpi: 94 gamma: 1.2
size: 690x291mm (27.17x11.46") diag: 762mm (30") modes: max: 2560x1080
min: 640x480
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070
SUPER/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 SUPER driver: nvidia v: 550.76 device-ID: 10de:1e84
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD
Graphics 630 (CML GT2) driver: mesa intel v: 24.0.6-arch1.2
device-ID: 8086:9bc5 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
API: ALSA v: k6.8.8-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 3b:00.0
IF: enp59s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
Local Storage: total: 953.87 GiB used: 545.98 GiB (57.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1032 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11111000 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 919.26 GiB size: 919.26 GiB (100.00%)
used: 545.98 GiB (59.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 919.26 GiB size: 919.26 GiB (100.00%)
ID-4: /var/log raw-size: 919.26 GiB size: 919.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.26 GiB size: 919.26 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.18 GiB used: 22.8 MiB (0.1%)
ID-2: swap-2 type: partition size: 34.3 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.0 C pch: 67.0 C mobo: N/A gpu: nvidia
temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 24%
Memory: total: 32 GiB available: 31.18 GiB used: 6.6 GiB (21.2%)
Processes: 395 Power: uptime: 8h 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2346 libs: 616 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2023-05-16
Last full system update: 2024-04-30
Failed units: nmb.service
