Greetings,
After one of the last Octopi updates I noticed that it no longer displays the global menu next to its title in the top panel. I did some quick searching and found nothing overly relevant to this issue. Because of this, I can no longer access any of the search utilities it provides (at least, not with the window decorations I am using). I also checked the help menu within Octopi, but none of the shortcuts it provides can access any of these functionalities. Any help would be appreciated.
Garuda-inxi:
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=acc91bbd-51b8-4669-9368-f85ecd75b0a1 rw rootflags=subvol=@
resume=UUID=5bb1f004-d544-4ddf-bfac-8a1cf21296d8 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: LENOVO product: ThinkPad W541 v: 1.0
Mobo: LENOVO model: ThinkPad W541 v: 1.0 serial: <superuser required>
BIOS: coreboot v: 4.20-410-g3e523b495c date: 06/17/2023
Info: model: Intel Core i7-4710MQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2737 high: 3293 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3293 2: 2825 3: 2802
4: 2493 5: 2494 6: 3004 7: 2496 8: 2495 bogomips: 39908
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Lenovo driver: nvidia
v: 470.239.06 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none empty: DP-3
bus-ID: 01:00.0 chip-ID: 10de:0ff6 class-ID: 0300
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-12:4 chip-ID: 5986:026a
class-ID: 0e02
unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: crocus
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: crocus device: 3 drv: swrast gbm: drv: crocus
surfaceless: drv: crocus wayland: drv: crocus x11: drv: crocus
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.0.3-arch1.2
device-ID: 8086:0416 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: Quadro K1100M driver: nvidia v: 470.239.06
device-ID: 10de:0ff6 surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Lenovo 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
chip-ID: 10de:0e1b class-ID: 0403
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-LM driver: N/A modules: e1000e port: 1040
bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-11:3 chip-ID: 8087:07dc
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 931.51 GiB used: 48.49 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-1: / raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
used: 48.49 GiB (5.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
ID-3: /var/log raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
ID-4: /var/tmp raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 58.0 C mobo: N/A
Memory: total: 16 GiB available: 15.58 GiB used: 5.21 GiB (33.5%)
Processes: 273 Power: uptime: 5h 47m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 6.18 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1941 libs: 442 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: kitty inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-07
Last full system update: 2024-03-31 ↻
