getting this error message while using localwp to export a website I'm developing. how to solve? where would I find that library version and where would I put it once found.
node: /home/cc/.config/Local/lightning-services/php-7.4.30+5/bin/linux/shared-libs/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /usr/bin/../lib/libnode.so.115)
╰─λ garuda-inxi
Kernel: 6.3.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=9e5bd559-ac66-48f8-bdd1-3ce700cb0fcc rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: Framework product: Laptop v: AB
serial:
Mobo: Framework model: FRANBMCP0B v: AB serial:
UEFI: INSYDE v: 03.07 date: 12/14/2021
ID-1: BAT1 charge: 52.7 Wh (100.0%) condition: 52.7/55.0 Wh (95.8%)
volts: 17.4 min: 15.4 model: NVT Framewo type: Li-ion serial:
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xAA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2347 high: 2800 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 2800 2: 2800 3: 2800
4: 989 5: 2800 6: 2800 7: 994 8: 2800 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
Screen-1: 0 s-res: 2256x1504 s-dpi: 162 s-size: 353x235mm (13.90x9.25")
s-diag: 424mm (16.7")
Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res: 2256x1504
dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
ratio: 3:2 modes: 2256x1504
API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.3.7-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
IF: wlp170s0 state: up mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0032
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 465.76 GiB used: 54.49 GiB (11.7%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 111130WD temp: 35.9 C scheme: GPT
used: 54.49 GiB (11.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.14 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 271 Uptime: 2h 44m wakeups: 57546 Memory: available: 31.14 GiB
used: 4.14 GiB (13.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 12 Packages: pm: pacman
pkgs: 1431 libs: 372 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-05-26
Last full system update: 2023-06-13
