I wondered if anyone else has come across the issue of needing to install glibc-eac in order for Insurgency Sandstorm to load properly and run. In many google posts and on protondb I see mention of this as an issue for Arch OS users. When I looked at using yay to install AUR version of glibc-eac, I found that the exact one was apparently already resident on my system, so I aborted. Is is possible that it needs to be reinstalled or is corrupted? I am too novice to make alterations that might blow up my system. I have other games that use EAC and they do run.
Thanks in advance for any input possible.
Barry
Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=73b3631e-3dec-4209-9c71-4928bd70fb46 rw rootflags=subvol=@
quiet rd.luks.uuid=a8e40cc9-41be-4434-8bf9-423936703f72
rd.luks.uuid=f79a930f-07d4-4043-878d-b926518407cc
resume=/dev/mapper/luks-f79a930f-07d4-4043-878d-b926518407cc loglevel=3
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop System: Dell product: Precision Tower 5810 v: N/A
serial: <superuser required> Chassis: type: 7 serial: <superuser required>
Mobo: Dell model: 0K240Y v: A01 serial: <superuser required> part-nu: 0617
uuid: <superuser required> UEFI-[Legacy]: Dell v: A34 date: 10/19/2020
Info: model: Intel Xeon E5-2687W v4 bits: 64 type: MT MCP arch: Broadwell
level: v3 note: check built: 2015-18 process: Intel 14nm family: 6
model-id: 0x4F (79) stepping: 1 microcode: 0xB000040
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 3381 high: 3500 min/max: 1200/3500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3147 2: 3374 3: 3500
4: 3500 5: 3500 6: 3500 7: 3500 8: 3500 9: 3345 10: 3500 11: 3500 12: 3500
13: 3500 14: 3500 15: 2495 16: 3500 17: 3500 18: 3500 19: 2292 20: 3500
21: 3500 22: 3500 23: 3500 24: 3500 bogomips: 143666
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
bus-ID: 04:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: Cubeternet GL-UPC822 UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:5 chip-ID: 1e4e:0102
class-ID: 0e02
Monitor-1: HDMI-A-1 res: 3440x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
navi22 LLVM 18.1.8 DRM 3.57 6.9.10-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.1.4-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland
Device-1: Intel C610/X99 series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20 class-ID: 0403
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-3: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:ab28
Device-4: SteelSeries ApS Arctis 1 Wireless
lanes: 1 mode: 1.1 bus-ID: 3-5:4 chip-ID: 1038:12b3 class-ID: 0300
API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f020 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 0c:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp12s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:6 chip-ID: 8087:0029
Hardware-1: Intel SATA Controller [RAID Mode] driver: ahci v: 3.0 port: f000
bus-ID: 00:1f.2 chip-ID: 8086:2826 rev: N/A class-ID: 0104
Local Storage: total: 1.03 TiB used: 947.78 GiB (90.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNJ128GCSU
tech: SSD serial: <filter> fw-rev: 0101 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721010KLA330
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: A9CA scheme: GPT
ID-1: / raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
used: 40.79 GiB (48.1%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-a8e40cc9-41be-4434-8bf9-423936703f72
ID-2: /home raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-3: /var/log raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-4: /var/tmp raw-size: 84.84 GiB size: 84.84 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
mapped: luks-f79a930f-07d4-4043-878d-b926518407cc
ID-2: swap-2 type: zram size: 31.26 GiB used: 1024 KiB (0.0%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 41.0 C mobo: N/A sodimm: SODIMM C gpu: amdgpu
temp: 60.0 C mem: 58.0 C
Fan Speeds (rpm): cpu: 1001 gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.26 GiB used: 6.9 GiB (22.1%)
Processes: 510 Power: uptime: 5h 49m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2138 libs: 603
tools: gnome-software,octopi,paru Compilers: clang: 18.1.8 gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-07-08
Last full system update: 2024-07-21 ↻
