Bottom line up front: Elden Ring doesn't stutter at all when I use Nobara Linux, and stutters a bunch on Garuda Linux. I'm not sure what settings, options, etc are different between the two that'd be causing the game to stutter on one distro and not the other. I'd prefer to use Garuda but I'm not sure how to make it run like Nobara as I'm still a novice when it comes to linux.
If you want additional information or if there’s a better place for me to post this, please let me know. I’m sorry for lacking additional detail that may be helpful. I’m still new to figuring some of this stuff out and I’m not sure what’s relevant or not. I’m also new to posting for tech support in general so I’m not entirely sure what to ask or where to ask it. Any linux wisdom provided here would be greatly appreciated.
Here's my output from the require command:
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3293a743-89eb-4b37-bc76-c02166704002 rw [email protected]
Type: Desktop System: Gigabyte product: X570 AORUS ELITE WIFI v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE WIFI v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F35
date: 07/08/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3650 high: 4549 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3597 2: 3588
3: 3596 4: 3599 5: 4549 6: 3599 7: 3618 8: 3595 9: 3599 10: 3597 11: 3599
12: 3804 13: 3591 14: 3592 15: 3597 16: 3624 17: 3688 18: 3599 19: 3596
20: 3596 21: 3598 22: 3596 23: 3596 24: 3591 bogomips: 177589
STIBP: always-on, RSB filling
Device-1: AMD Vega 20 [Radeon VII] driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 0b:00.0 chip-ID: 1002:66af class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: LG (GoldStar) 27GK750F serial: <filter> built: 2019 res: 1920x1080
hz: 60 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73")
diag: 685mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Acer GN246HL
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
OpenGL:
renderer: AMD Radeon VII (vega20 LLVM 13.0.1 DRM 3.44 5.17.9-zen1-1-zen)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: AMD Vega 20 HDMI Audio [Radeon VII] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.1
chip-ID: 1002:ab20 class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.3:7 chip-ID: 1038:12ad
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-5:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 6.36 TiB used: 2.31 TiB (36.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 512GB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: SVN163
temp: 24.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 480GB
type: SSD serial: <filter> rev: 04RL scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT2000MX500SSD1
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT2000MX500SSD1
type: SSD serial: <filter> rev: 023 scheme: MBR
used: 33.18 GiB (7.4%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 31.35 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 16.8 C mobo: 16.8 C gpu: amdgpu temp: 39.0 C
mem: 40.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 880
Processes: 461 Uptime: 1h 52m wakeups: 0 Memory: 31.35 GiB
used: 7.69 GiB (24.5%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1940 lib: 528 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-22
Last full system update: 2022-05-22 ↻
