Get an error while using garuda-update
Since 3 days I can’t play anymore because there is some problem with the update with Zen/Lts Kernel and Nvidia. garuda-update remote fix didn’t help either.
What else can I try?
Kernel: 6.6.39-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=db7fdaf0-1b5f-4a15-9e6f-2898016bc93c rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: ASUSTeK product: ROG Strix G713QR_G713QR v: 1.0
Mobo: ASUSTeK model: G713QR v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713QR.327
date: 03/29/2022
ID-1: BAT0 charge: 77.8 Wh (95.0%) condition: 81.9/90.0 Wh (91.0%)
volts: 16.8 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 462 high: 1397 min/max: 400/4890 scaling:
4: 1397 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 105442
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: N/A alternate: nouveau non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 52.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
s-diag: 1245mm (49.01")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: left model: EIZO NANAO CG241W
serial: <filter> built: 2013 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 519x324mm (20.43x12.76") diag: 616mm (24.2") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,right model: BOE Display 0x0a08
built: 2021 res: 2560x1440 hz: 165 dpi: 171 gamma: 1.2
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.3-arch1.1
renoir LLVM 18.1.8 DRM 3.54 6.6.39-1-lts) device-ID: 1002:1638
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.3-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
API: ALSA v: k6.6.39-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-3: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:4
chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp6s0f3u1u2 state: down mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
Local Storage: total: 1.4 TiB used: 155.12 GiB (10.8%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVLB512HAJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 4L1QEXA7 temp: 34.9 C scheme: GPT
used: 155.12 GiB (32.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 63.6 C mobo: 36.0 C gpu: amdgpu temp: 53.0 C
Memory: total: 16 GiB note: est. available: 15.05 GiB used: 4 GiB (26.6%)
Processes: 365 Power: uptime: 9m states: freeze,mem,disk suspend: s2idle
image: 6.01 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1813 libs: 543 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date:     2024-05-01
Last full system update: 2024-07-14
Here is the error message during the update
garuda-update
[sudo] Passwort für matthias:
:: Paketdatenbanken werden synchronisiert …
garuda ist aktuell
core ist aktuell
extra ist aktuell
multilib ist aktuell
chaotic-aur ist aktuell
blackarch ist aktuell
garuda wird heruntergeladen …
core wird heruntergeladen …
extra wird heruntergeladen …
multilib wird heruntergeladen …
chaotic-aur wird heruntergeladen …
blackarch wird heruntergeladen …
spawn pacman -Su
there is nothing to do
--> A problem with the NVIDIA drivers has been detected
---> Building NVIDIA DKMS module for kernel 6.6.39-1-lts
Module nvidia 555.58.02 is not installed for kernel 6.6.39-1-lts (x86_64). Skipping...
Module nvidia 555.58.02 is not built for kernel 6.6.39-1-lts (x86_64). Skipping...
Deleting module nvidia-555.58.02 completely from the DKMS tree.
Sign command: /usr/lib/modules/6.6.39-1-lts/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Creating symlink /var/lib/dkms/nvidia/555.58.02/source -> /usr/src/nvidia-555.58.02
Building module:
Cleaning build area...
'make' -j16 IGNORE_PREEMPT_RT_PRESENCE=1 NV_EXCLUDE_BUILD_MODULES='__EXCLUDE_MODULES' KERNEL_UNAME=6.6.39-1-lts modules...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.6.39-1-lts (x86_64)
Consult /var/lib/dkms/nvidia/555.58.02/build/make.log for more information.
---> Failed to build NVIDIA DKMS module for kernel 6.6.39-1-lts
---> Building NVIDIA DKMS module for kernel 6.9.9-zen1-1-zen
Module nvidia 555.58.02 is not installed for kernel 6.9.9-zen1-1-zen (x86_64). Skipping...
Module nvidia 555.58.02 is not built for kernel 6.9.9-zen1-1-zen (x86_64). Skipping...
Sign command: /usr/lib/modules/6.9.9-zen1-1-zen/build/scripts/sign-file
Building module:
'make' -j16 IGNORE_PREEMPT_RT_PRESENCE=1 NV_EXCLUDE_BUILD_MODULES='__EXCLUDE_MODULES' KERNEL_UNAME=6.9.9-zen1-1-zen modules...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.9.9-zen1-1-zen (x86_64)
---> Failed to build NVIDIA DKMS module for kernel 6.9.9-zen1-1-zen
System updated! 🐧
Have you checked this log as suggested?
Maybe you need the headers for that kernel?
sudo pacman -S linux-zen-headers
Additionally
I’m not an Nvidia user but I guess that for the LTS kernel you need the nvidia-lts package?
I have reinstalled the header - no improvement. Reinstalling the driver did not help either.
Here is the log file that is written during the update…
DKMS make.log for nvidia-555.58.02 for kernel 6.9.9-zen1-1-zen (x86_64)
So 14. Jul 11:47:19 CEST 2024
make[1]: Verzeichnis „/usr/lib/modules/6.9.9-zen1-1-zen/build“ wird betreten
The C compiler 'gcc' does not appear to be able to
create object files.  Please make sure you have
your Linux distribution's libc development package
installed and that 'gcc' is a valid C compiler
name.
*** Failed CC sanity check. Bailing out! ***
make[3]: *** [/var/lib/dkms/nvidia/555.58.02/build/Kbuild:276: cc_sanity_check] Fehler 1
make[3]: *** Es wird auf noch nicht beendete Prozesse gewartet …
Warning: Compiler version check failed:
The major and minor number of the compiler used to
compile the kernel:
gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0
does not match the compiler used here:
Copyright (C) 2024 Free Software Foundation, Inc.
Dies ist freie Software; die Kopierbedingungen stehen in den Quellen. Es
gibt KEINE Garantie; auch nicht für MARKTGÄNGIGKEIT oder FÜR SPEZIELLE ZWECKE.
It is recommended to set the CC environment variable
to the compiler that was used to compile the kernel.
To skip the test and silence this warning message, set
the IGNORE_CC_MISMATCH environment variable to "1".
However, mixing compiler versions between the kernel
and kernel modules can result in subtle bugs that are
difficult to diagnose.
*** Failed CC version check. ***
make[2]: *** [/usr/lib/modules/6.9.9-zen1-1-zen/build/Makefile:1916: /var/lib/dkms/nvidia/555.58.02/build] Fehler 2
make[1]: *** [Makefile:240: __sub-make] Fehler 2
make[1]: Verzeichnis „/usr/lib/modules/6.9.9-zen1-1-zen/build“ wird verlassen
make: *** [Makefile:89: modules] Fehler 2
Have you tried the nvidia-lts package for the linux-lts kernel?
You cant build 555 for lts at least not yet.
i have had all kind of problems with the nivida drivers lately with my rtx 4080 card, and found the solution to be installing nvidia-all, and picking the latest available driver. However nvidia-all will provide a list of compatible choices for you to pick from.
#open terminal and follow below instructions
git clone GitHub - Frogging-Family/nvidia-all: Nvidia driver latest to 396 series AIO installer
cd nvidia-all
(sudo pacman -S mkinitcpio)
sudo mkinitcpio -P
sudo grub-mkconfig -o /boot/grub/grub.cfg
reboot
Hoping you get your issues fixed like i did.
Isn’t this for 555 and LTS?
https://archlinux.org/packages/extra/x86_64/nvidia-lts/
There are no issues reported so I thought it was something to try. And outside dkms.
