General display issues after attempting swap to GDM from SDDM
I made an attempt to swap from SDDM to GDM as I prefered the look and its caused all kinds of issues.
sudo pacman -S gdm
sudo systemctl enable gdm.service -f
it’s now caused weird display issues. Stuff like overlapping monitors, (running two monitors) No individual scaling of monitors. and just general weird display things. Image attached is the weird display things, (that odd bezel) + neofetch. (as well im getting odd performance issues)
Can’t find anyone else with similar problems. and after uninstalling GDM and using snapper to revert to old backups, nothing has changed.
New to garuda, not linux. any help appreciated!
Screenshot of display issues
Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5e2a69e7-286c-41d9-a40c-4fe4300f8574 rw rootflags=subvol=@
quiet resume=UUID=ef6eabd4-00d1-44a0-9c6f-3324f2ef6f56 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Dell product: Inspiron 5680 v: 2.1.0
Mobo: Dell model: 0PXWHK v: A00 serial: <superuser required> UEFI: Dell
v: 2.1.0 date: 05/10/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1116 high: 4601 min/max: 800/4600 scaling:
5: 800 6: 800 7: 4601 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 76799
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Dell driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-3,HDMI-A-1 empty: DP-1,DP-2,DVI-D-1
bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Screen-1: 0 s-res: 6400x2160 s-dpi: 162 s-size: 1003x341mm (39.49x13.43")
s-diag: 1059mm (41.71")
Monitor-1: DP-3 mapped: DP-4 note: disabled pos: top-left
model: Dell P2715Q serial: <filter> built: 2017 res: 3840x2160 hz: 60
dpi: 163 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,bottom-r
model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2018 res: 2560x1080
dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 2560x1080 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.276 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 545.29.06
device-ID: 10de:1b81 surfaces: xcb,xlib
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA GP104 High Definition Audio vendor: Dell
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.7.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:3 chip-ID: 0cf3:e009
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.45 TiB used: 40.26 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC45 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3320418AS
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: HP35 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: SK Hynix model: SC311 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 14.34 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 221.21 GiB size: 221.21 GiB (100.00%)
used: 40.26 GiB (18.2%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 221.21 GiB size: 221.21 GiB (100.00%)
ID-4: /var/log raw-size: 221.21 GiB size: 221.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.21 GiB size: 221.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 58.0 C mobo: N/A gpu: nvidia temp: 65 C
Fan Speeds (rpm): cpu: 1194 fan-2: 1436 gpu: nvidia fan: 42%
Processes: 320 Uptime: 8m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.42 GiB used: 4.47 GiB (29.0%) Init: systemd v: 255
Packages: 1830 pm: pacman pkgs: 1824 libs: 528 tools: octopi,paru,yay
pm: flatpak pkgs: 6 Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2024-01-10
Last full system update: 2024-01-29
Failed units:            systemd-vconsole-setup.service
I am assuming you installed at least a recent ISO because dracut is listed… but why is latte-dock in use? Please remove that, we moved away from that quite some time ago as it is unmaintained. I assume at least some of your problems could be caused from that.
Relevant wiki page: Dr460nized migration info | Garuda Linux wiki
Ah, I installed that myself cause I like it and have used previously. I don’t think it’s causing issues as it’s worked fine, and things only went wrong after swapping to GDM.
Did you disable SDDM?
I think so? How would this be done so i remember if I did it or not?
How did you enable GDM? Think about it…
EDIT: The -f flag should have disabled SDDM, but did it? Also, you run Nvidia, and the Arch Wiki says this takes special consideration with GDM. Did you read the Arch Wiki on SDDM & GDM & Nvidia?
