When using the chrome app Geforce Now if you use the keyboard to play games it loses focus on the application and brings focus to the taskbar. It is only keyboard that causes this. If I use gamepad the app will stay in focus and work fine for its entire time opened. If I press a key (example used is W for movement) the app does not lose focus until that key is released. upon releasing the key pressed it shows the taskbar and i can no longer use the keyboard in the app, until I alt tab back into the app.
I made a video showing what happens but unable to post do to rules.
I have found no similar posts about this problem.
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f03802ec-bb0b-4957-a58e-66b3d08691d9 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: HP product: HP EliteDesk 800 G3 TWR v: N/A
Mobo: HP model: 8298 v: KBC Version 06.29 serial: <superuser required>
part-nu: 1FY74UT#ABA uuid: <superuser required> UEFI: HP v: P01 Ver. 02.48
date: 10/05/2023
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 812 high: 900 min/max: 800/4000 scaling:
5: 800 6: 800 7: 900 8: 800 bogomips: 54398
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: none
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
Device-2: AMD Navi 24 [Radeon RX 6400/6500 XT/6500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-4 empty: DP-4 bus-ID: 03:00.0
chip-ID: 1002:743f class-ID: 0300
alternate: fbdev,intel,vesa dri: iris gpu: i915,amdgpu display-ID: 0
Monitor-1: HDMI-A-4 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:1912 memory: 30.49 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 6400 (RADV NAVI24) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:743f surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: Intel HD Graphics 530 (SKL GT2)
driver: mesa intel v: 24.0.3-arch1.1 device-ID: 8086:1912
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.1 (LLVM 17.0.6)
Device-1: Intel 200 Series PCH HD Audio vendor: Hewlett-Packard
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: CMTECK driver: snd-usb-audio type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 5678:1000 class-ID: 0300
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 168c:0030 class-ID: 0280
Local Storage: total: 953.87 GiB used: 135.66 GiB (14.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: M600 MTFDDAK1T0MBF
size: 953.87 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: MU05 scheme: GPT
used: 135.66 GiB (14.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 31.22 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 30.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 56.0 C
Memory: total: 32 GiB available: 31.22 GiB used: 2.12 GiB (6.8%)
Processes: 263 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1898 libs: 539 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
Garuda (2.6.23-1):
System install date: 2024-03-15
Last full system update: 2024-03-17
