Recently I started noticing some lag in the display and my FlightGear simulator has started crashing. It all started maybe within a week.
So today I decided to get some Geekbench results and to my surprise, it has halved as compared to when I had freshly installed Garuda!
I tried disabling Secure Boot(which I had recently implemented), disabling Gnome extensions, removing vulkan-radeon(which I had recently installed for running x-plane 12 demo),
and all of this doesn't seem to have any impact on the benchmarks.
I even tried booting from linux kernel from the arch repos, but no difference.
(As you can see in the last benchmark)
❯ garuda-inxi
Kernel: 5.19.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=974f3ce6-ba35-41c5-a737-23cb1e2b873f rw rootflags=subvol=@
lsm=landlock,lockdown,yama,integrity,apparmor,bpf quiet splash
mitigations=off rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Acer product: Swift SF314-43 v: V1.04
Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required>
UEFI: Insyde v: 1.04 date: 07/28/2021
ID-1: BAT1 charge: 50.8 Wh (100.0%) condition: 50.8/53.2 Wh (95.5%)
volts: 13.1 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: full
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x68 (104) stepping: 1 microcode: 0x8608102
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1399 high: 1400 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1398 2: 1400
3: 1400 4: 1400 5: 1400 6: 1400 7: 1397 8: 1400 9: 1400 10: 1400 11: 1400
12: 1400 bogomips: 50325
Type: retbleed status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:164c class-ID: 0300
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 0408:a094 class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting
Monitor-1: eDP-1 model: AU Optronics 0x683d built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.12-arch1-1) v: 4.6
Mesa 22.1.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Acer Incorporated
ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Acer Incorporated
ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.19.12-arch1-1 running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: enp3s0f3u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Device-1: Lite-On Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:4 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 53.11 GiB (11.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFK0S03
temp: 41.9 C scheme: GPT
ID-1: / raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 15.84 GiB
(24.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%) used: 2 MiB
(0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 64 GiB size: 64 GiB (100.00%) used: 7.98 GiB
(12.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 15.84
GiB (24.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 15.84
ID-1: swap-1 type: zram size: 7.12 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 357 Uptime: 18m wakeups: 1652 Memory: 7.12 GiB used: 3.38 GiB
(47.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 1511 pm: pacman pkgs: 1488 libs: 379
tools: gnome-software,pamac,paru pm: flatpak pkgs: 23 Shell: Zsh v: 5.9
running-in: terminator inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-28
Last full system update: 2022-09-29
