Hi, after today's update, a clean screen. It is not possible to select a user and a session.
inxi -Faz
System: Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=25bdb391-e52a-4575-8f27-23aa4b24a0c0 rw
rootflags=subvol=@ quiet splash pcie_aspm=off rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1, LightDM 1.30.0 Distro: Garuda Linux
Machine: Type: Desktop Mobo: Gigabyte model: GA-A55M-S2V serial: <filter> BIOS: Award v: F2 date: 07/08/2011
CPU: Info: Quad Core model: AMD Athlon II X4 631 bits: 64 type: MCP arch: Fusion family: 12 (18) model-id: 1 stepping: 0
microcode: 3000027 cache: L2: 4 MiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 20799
Speed: 1314 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1314 2: 2233 3: 1652 4: 1793
Type: spec_store_bypass status: Not affected
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 445x278mm (17.5x10.9") s-diag: 525mm (20.7")
Monitor-1: HDMI-0 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fb8 class-ID: 0403
Device-3: Creative Labs EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] driver: snd_emu10k1 v: kernel
bus-ID: 03:06.0 chip-ID: 1102:0004 class-ID: 0401
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8168 v: 8.049.02-NAPI
modules: r8169 port: ee00 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Conwise CW6622 type: USB driver: btusb v: 0.8 bus-ID: 5-4:2 chip-ID: 0e5e:6622 class-ID: e001
Drives: Local Storage: total: 1.47 TiB used: 452.33 GiB (30.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: SATA SSD size: 111.79 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 61.2 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD5000AAKX-001CA0 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H15 scheme: MBR
Partition: ID-1: / raw-size: 94.46 GiB size: 94.46 GiB (100.00%) used: 32.51 GiB (34.4%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-2: /home raw-size: 233.02 GiB size: 228.36 GiB (98.00%) used: 120.18 GiB (52.6%) fs: ext4 dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 94.46 GiB size: 94.46 GiB (100.00%) used: 32.51 GiB (34.4%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-4: /var/tmp raw-size: 94.46 GiB size: 94.46 GiB (100.00%) used: 32.51 GiB (34.4%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-1: swap-1 type: zram size: 7.75 GiB used: 114.8 MiB (1.4%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 74.0 C mobo: 38.0 C gpu: nvidia temp: 46 C
Fan Speeds (RPM): cpu: 1146 fan-1: 1163 fan-3: 0 gpu: nvidia fan: 36%
Power: 12v: N/A 5v: 2.96 3.3v: N/A vbat: 3.30
Info: Processes: 318 Uptime: 1h 43m wakeups: 0 Memory: 7.75 GiB used: 5.25 GiB (67.8%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1859 apt: 0 pacman: 1848 lib: 509 flatpak: 11
Shell: fish v: 3.3.1 running-in: gnome-terminal inxi: 3.3.06
