Garuda gnome 220101: I can use gestures by default on fresh install. I can pinch to see my open applications and three finger swipe up to change desktops by default. Where do I change this?
I tried the Mouse & Touchpad settings. I also tried the gestures app but when it opens it's blank and my gestures stop working until I remove the blank config file it creates in the ~/.config folder. I tried touchegg and configuring with touche but it says gnome is using these gestures already so I'm at a lost.
If anyone could help by pointing me in the right direction I'd be grateful.
Thanks!
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0325cfb9-07d3-4737-9971-9c628e932a4d rw rootflags=subvol=@
quiet
cryptdevice=UUID=c50056da-5063-4c3a-b0b9-717c9e6d570b:luks-c50056da-5063-4c3a-b0b9-717c9e6d570b
root=/dev/mapper/luks-c50056da-5063-4c3a-b0b9-717c9e6d570b splash
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 82B1 v: Lenovo Legion 5 15ARH05H
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05H
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: FSCN18WW date: 01/01/2021
ID-1: BAT0 charge: 58.1 Wh (100.0%) condition: 58.1/60.0 Wh (96.9%)
volts: 17.2 min: 15.4 model: SMP L19M4PC0 type: Li-poly serial: <filter>
status: Full cycles: 22
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1398 high: 1429 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1429 9: 1396 10: 1397 11: 1396
12: 1397 13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 92624
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-3:2 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DP-2 res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 1000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
bus-ID: 5-3:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 476.94 GiB used: 19.12 GiB (4.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS512GD9TNI-L2A0B size: 476.94 GiB block-size: physical: 512 B
rev: 11010C10 temp: 28.9 C scheme: GPT
used: 19.12 GiB (4.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c50056da-5063-4c3a-b0b9-717c9e6d570b
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 38 C
Processes: 380 Uptime: 38m wakeups: 1 Memory: 15.56 GiB
used: 3.31 GiB (21.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1269 lib: 344 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.11
