This has been plaguing the bin for at least a few weeks now but it seems no one’s reported it o_o so here we go.
The title says it all - all the page says is
Loading…
In case this message never disappears please have a look at [this FAQ for information to troubleshoot](https://github.com/PrivateBin/PrivateBin/wiki/FAQ#why-does-the-loading-message-not-go-away).
I’ve tried Chromium and Librewolf, and tried toggling Ublock Origin to make sure it really wasn’t blocking the page from loading, but nothing changed no matter what I tried. Even getting a new computer didn’t fix it
If there’s any additional information needed to help diagnose the problem, let me know and I’ll provide what I can
Kernel: 6.6.10-lqx1-4-lqx arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm parameters: audit=0
intel_pstate=disable rcupdate.rcu_expedited=1
root=UUID=867152de-1564-471a-96a0-6a749ff830c1 rw rootflags=subvol=GQtile
loglevel=3 ibt=off radeon_modeset=1 driver=nonfree
initrd=\GQtile\boot\initramfs-linux-lqx.img
Desktop: Qtile v: 0.23.0 wm: LG3D vt: 2 dm: SDDM Distro: Garuda Linux
Type: Mini-pc System: Micro (HK) Tech product: Venus series v: N/A
Mobo: Shenzhen Meigao Equipment model: F7BSC serial: <superuser required>
UEFI: American Megatrends LLC. v: 1.07 date: 09/01/2023
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
microcode: 0xA704103
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2751 high: 4689
min/max: 400/5263:6228:5583:5743:5423:5903:6067 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4689 2: 4684
3: 3726 4: 3751 5: 3743 6: 3748 7: 400 8: 400 9: 4007 10: 400 11: 4682
12: 400 13: 3911 14: 4689 15: 400 16: 400 bogomips: 127753
Device-1: AMD Phoenix1 driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix
process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
HDMI-A-2 bus-ID: c4:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 49.0 C
Display: x11 server: X.Org v: 21.1.10 compositor: Picom v: git-b700a
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Dell P2423D serial: <filter>
built: 2023 res: 2560x1440 hz: 60 dpi: 123 gamma: 1.2
max: 2560x1440 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.2-arch1.2
gfx1103_r1 LLVM 16.0.6 DRM 3.54 6.6.10-lqx1-4-lqx) device-ID: 1002:15bf
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV GFX1103_R1) driver: mesa radv v: 23.3.2-arch1.2
device-ID: 1002:15bf surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c4:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_ps
v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: c4:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c4:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.10-lqx1-4-lqx status: kernel-api
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8125
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 8086:2725 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 953.87 GiB used: 318.72 GiB (33.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PGP41024Q-A0
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 30.9 C
ID-1: / raw-size: 848.35 GiB size: 848.35 GiB (100.00%)
used: 318.68 GiB (37.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 35.8 MiB (7.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 848.35 GiB size: 848.35 GiB (100.00%)
ID-4: /var/log raw-size: 848.35 GiB size: 848.35 GiB (100.00%)
ID-5: /var/tmp raw-size: 848.35 GiB size: 848.35 GiB (100.00%)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: swap-2 type: zram size: 60.54 GiB used: 3.8 GiB (6.3%) priority: 100
System Temperatures: cpu: 53.4 C mobo: N/A gpu: amdgpu temp: 49.0 C
Processes: 510 Uptime: 19h 40m wakeups: 0 Memory: total: N/A
available: 60.54 GiB used: 11.15 GiB (18.4%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1647 libs: 441 tools: paru Shell: fish v: 3.7.0
running-in: alacritty inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-06
Last full system update: 2024-01-09
Failed units: archlinux-keyring-wkd-sync.service
