Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f960cca8-1246-4004-9f44-05fddda87b3b rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: Z790 LiveMixer
Megatrends LLC. v: 3.09 date: 10/07/2022
Info: model: 13th Gen Intel Core i9-13900KF bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 1467 high: 5800 min/max: 800/5500:5800:4300 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 5800 12: 800
13: 5500 14: 800 15: 5500 16: 800 17: 4267 18: 800 19: 4299 20: 800
21: 800 22: 800 23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800
30: 800 31: 800 32: 800 bogomips: 191692
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: MSI G321CU built: 2022
res: 3840x2160 hz: 60 dpi: 140 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 3840x2160 min: 640x480
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
navi31 LLVM 16.0.6 DRM 3.57 6.7.6-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.3.276 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
Device-2: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 22.3 TiB used: 8.83 TiB (39.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
model: T-FORCE TM8FPZ004T size: 3.64 TiB block-size: physical: 512 B
fw-rev: EIFM51.3 temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Seagate model: BarraCuda Q5
ZP2000CV30001 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU5SH017
temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC38 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST12000NM0127
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: G006 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40NMZW-11GX6S1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1018 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Toshiba model: MQ03UBB200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400 serial: <filter>
fw-rev: 5438 scheme: MBR
ID-7: /dev/sde maj-min: 8:64 vendor: Verbatim model: STORE N GO
size: 14.93 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 5.00 scheme: GPT
ID-1: / raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
used: 352.44 GiB (70.5%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:5
used: 648 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:6
ID-3: /home raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
ID-4: /var/log raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
ID-5: /var/tmp raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.86 GiB used: 185.7 MiB (0.4%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32
System Temperatures: cpu: 12.0 C mobo: 42.0 C gpu: amdgpu temp: 51.0 C
mem: 58.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0 fan-3: 1170 fan-4: 0 fan-5: 531
fan-6: 3176 fan-7: 0 gpu: amdgpu fan: 0
Memory: total: 48 GiB available: 46.86 GiB used: 7.54 GiB (16.1%)
Processes: 637 Power: uptime: 15h 33m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 18.73 GiB services: org_kde_powerdevil,
Packages: 2196 pm: pacman pkgs: 2191 libs: 617 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 5 Compilers: clang: 16.0.6
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: lxterminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-09
Last full system update: 2024-02-28 ↻
i have noticed, for some time now, that neither auto hide, or windows cover, works on the main Garuda panel, after i have suspended my computer and wake it up again.
i use this command successfully in my script to auto hide, or cover the panel with my windows for that matter, otherwise.
qdbus org.kde.plasmashell /PlasmaShell org.kde.PlasmaShell.evaluateScript “panels()[0].hiding = "autohide"”
Is there a way, apart of rebooting, to get the panel to work again?
Thanks.
