λ garuda-inxi
Kernel: 6.1.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=711d187b-b9e9-4449-8e26-33fa1ef169da rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2601 date: 05/17/2022
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4039 high: 5111 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 5111 2: 5019 3: 3800
4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 5101
13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121596
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1, DP-2,
DVI-D-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 49.0 C
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: AOC Q32G1WG4 serial: <filter> built: 2019
res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.1.8-zen1-1-zen running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.21 TiB used: 1.42 TiB (44.4%)
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211070WD temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
used: 13.58 GiB (5.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1174
Processes: 378 Uptime: 1h 24m wakeups: 0 Memory: 31.25 GiB
used: 3.6 GiB (11.5%) Init: systemd v: 252 default: graphical
pkgs: 1583 libs: 368 tools: gnome-software,pamac,paru,pikaur pm: flatpak
pkgs: 0 Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-28
Last full system update: 2023-01-28
I've never enjoyed using a Linux distribution as much as I am using Garuda Linux.
And I was mistaken. Gnome is enjoyable, but KDI is my closest companion.
I've been switching desktops, and among them all
Fully broken was garuda-wayfire-linux-zen-221019
resuming in live mode continuously
I couldn't install anything, at all.
not being able to access the internet or delete anything
it was very awful.
If you have any knowledge about the reasons behind this distro's behavior, please let me know.
it was this file garuda-wayfire-linux-zen-221019
it was a torrent
