Hi fellas,
Is Vaultwarden unaccessable from the Bitwarden app?
I'm recently unable to access the vault using Web Vault Server URL https://bitwarden.garudalinux.org/#
However, I can access Vaultwarden from the web browser just fine.
Thanks,
GM
Hi fellas,
Thanks,
GM
It should be accessible - I'm using it successfully via browser extension. Is the "#" intentional?
You are correct. My mistake ... user error.
I removed the /#/ and placed the URL in the app's server url field and it works perfectly from the Bitwarden apps across platforms.
Thanks @dr460nf1r3
Have a good one!
Welcome back BTW @GreenMartian .
Hello sir, good to see you!
Been dabblin’ a little bit … returned to your new(ish) Gnome spin on a new laptop.
Tossed a couple bucks in the FossHost kitty.
Much appreciated, good to see you as well.
