Instead of using my headphone/earphone for audio input garuda is for some reason picking up audio from the inbuilt mic of my laptop.
I tried searching in archwiki but the solution mentioned there required pulse audio, my device is however using pipewire-pulse and i was unable to fix the issue using wiki. i tried uninstalling pipewire-pulse to install pulseaudio but it was a dependency for pipewire-support which in turn is a dependency for something else so I am basically stuck, any help is appreciated.
To add, earlier the microphone was picking a lot of static up as well, changing profile in recording devices of audio setting to 'pro audio' from 'analog stereo duplex' fixed the static issue, for reference I am running garuda on a lenovo ideapad 520.
Just post your garuda-inxi as text, please.
CPU: quad core Intel Core i5-8250U (-MT MCP-) speed/min/max: 800/400/3400 MHz
Kernel: 5.18.7-zen1-1-zen x86_64 Mem: 2485.5/7730.0 MiB (32.2%)
Procs: 277 Shell: fish inxi: 3.3.19
Please, full garuda-inxi between
like
Kernel: 5.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ed159bee-f3f4-4cb1-aeff-997938929ff7 rw [email protected]
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Convertible System: LENOVO product: 82BG v: Yoga 9 14ITL5
serial: <superuser required> Chassis: type: 31 v: Yoga 9 14ITL5
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709WIN
serial: <superuser required> UEFI: LENOVO v: EHCN65WW date: 07/01/2021
ID-1: BAT0 charge: 37.8 Wh (65.3%) condition: 57.9/60.0 Wh (96.5%)
volts: 7.9 min: 7.7 model: SMP BASE-BAT type: Li-poly serial: <filter>
status: N/A cycles: 112
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1140 high: 1958 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1958 2: 984 3: 927
4: 1083 5: 974 6: 1027 7: 1168 8: 1000 bogomips: 47923
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 13d3:56b2 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
Monitor-1: eDP-1 model: LG Display 0x061f built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.18.7-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 51.25 GiB (10.7%)
model: PC SN730 SDBPNTY-512G-1101 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11170001 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 250 GiB size: 250 GiB (100.00%) used: 51.22 GiB (20.5%)
used: 29.2 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 250 GiB size: 250 GiB (100.00%)
used: 51.22 GiB (20.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 250 GiB size: 250 GiB (100.00%)
ID-5: /var/tmp raw-size: 250 GiB size: 250 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.22 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 273 Uptime: 1h 13m wakeups: 1204 Memory: 15.22 GiB
used: 4.32 GiB (28.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1400
lib: 354 Shell: fish v: 3.4.1 running-in: xfce4-terminal inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2021-11-30
Last full system update: 2022-07-02 ↻
root=UUID=d7ede459-c810-4e25-9e41-16cdd8eb2bac rw [email protected]
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: LENOVO product: 81BF v: Lenovo ideapad 520-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 520-15IKB
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
serial: <superuser required> UEFI: LENOVO v: 6JCN33WW date: 06/30/2020
ID-1: BAT0 charge: 14.8 Wh (100.0%) condition: 14.8/35.0 Wh (42.4%)
volts: 8.4 min: 7.6 model: LGC L16L2PB3 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 790 high: 800 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 721 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 28800
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Realtek EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:4
chip-ID: 0bda:58ea class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x06c6 built: 2016
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 22.1.2 direct render: Yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-7:3 chip-ID: 0cf3:e300 class-ID: e001
address: <filter>
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.82 TiB used: 12.77 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
type: HDD rpm: 5400 serial: <filter> rev: LDM2 scheme: GPT
ID-1: / raw-size: 620.52 GiB size: 620.52 GiB (100.00%)
used: 12.77 GiB (2.1%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat dev: /dev/sda6 maj-min: 8:6
ID-3: /home raw-size: 620.52 GiB size: 620.52 GiB (100.00%)
ID-4: /var/log raw-size: 620.52 GiB size: 620.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 620.52 GiB size: 620.52 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C pch: 44.0 C mobo: N/A
Processes: 231 Uptime: 14m wakeups: 1 Memory: 7.55 GiB
used: 2.49 GiB (33.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1205
lib: 311 flatpak: 0 Shell: fish v: 3.4.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-02-25
Between three tilde
If your headset has a 3.5mm jack, depending on your device sometimes ALSA assumes they are just headphones. On my laptop it was necessary to make a little config file to fix this.
sudo micro /etc/modprobe.d/headset.conf
It doesn't have to be named "headset", but it does have to end in ".conf" to work. It will be an empty file, just add this line:
options snd-hda-intel model=dell-headset-multi
Exit, save, reboot and try again.
If the device is being recognized correctly but is just not being used by the application you are running, this is where I would start: Advanced Linux Sound Architecture/Troubleshooting - ArchWiki
fixed the issue using hdajackretask, used it to override inbuilt microphone and disable it in realtek audio codec and totally stop it from being used, after that pulseaudio/pipewire automatically started using duplex earphones for input.
con is that the internal microphone is totally disabled now, will need to enable it again and reboot to use it
leaving this comment here as a solution for someone else who might encounter this issue
thank you for taking the time to respond, after a lot of tinkering i found the solution regardless, i have left the solution as a reply in case someone else has the same issue
system
closed
4 July 2022 19:40
#10
