Hi garuda community , well this is similar to the problem's solution mention in this thread:
but the thing is that I have tried all the things written there but nothing worked it still shows me this:
╭─[email protected] in ~ took 17s
╰─λ upd
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
resolving dependencies...
Packages (1) garuda-update-1.3.1-1
Total Download Size: 0.00 MiB
Total Installed Size: 0.00 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
garuda-update-1.3.1-1-any 3.6 KiB 3.07 KiB/s 00:01 [-------------------------------------] 100%
(1/1) checking keys in keyring [-------------------------------------] 100%
(1/1) checking package integrity [-------------------------------------] 100%
error: garuda-update: signature from "Nico Jensch (Chaotic-AUR) <[email protected]>" is invalid
:: File /var/cache/pacman/pkg/garuda-update-1.3.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Refreshing mirrorlists using reflector, be patient please..
[2021-11-09 14:25:59] WARNING: failed to rate http(s) download (https://mirror.telepoint.bg/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-09 14:26:05] WARNING: failed to rate http(s) download (https://arch.mirror.jsc.mx/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-09 14:26:11] WARNING: failed to rate http(s) download (https://mirror.cyberbits.asia/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-09 14:26:17] WARNING: failed to rate http(s) download (https://europe.mirror.pkgbuild.com/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-09 14:26:24] WARNING: failed to rate http(s) download (https://america.mirror.pkgbuild.com/community/os/x86_64/community.db): Download timed out after 5 second(s).
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2021-11-09 08:56:24 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2021-11-09 08:55:52 UTC
# Last Check: 2021-11-09 08:40:12 UTC
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://arch.mirror.jsc.mx/$repo/os/$arch
Server = https://mirror.cyberbits.asia/archlinux/$repo/os/$arch
Server = https://europe.mirror.pkgbuild.com/$repo/os/$arch
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
core 137.9 KiB 26.5 KiB/s 00:05 [-------------------------------------] 100%
extra 1568.6 KiB 107 KiB/s 00:15 [-------------------------------------] 100%
community 5.8 MiB 200 KiB/s 00:30 [-------------------------------------] 100%
multilib 150.3 KiB 19.1 KiB/s 00:08 [-------------------------------------] 100%
chaotic-aur 1595.7 KiB 228 KiB/s 00:07 [-------------------------------------] 100%
Checking for keyring update before starting full system update..
warning: garuda-hotfixes-1.0.4-1 is up to date -- skipping
warning: archlinux-keyring-20211028-1 is up to date -- skipping
warning: chaotic-keyring-20210617-1 is up to date -- skipping
there is nothing to do
Packages (12) btrfs-progs-5.15-1 game-devices-udev-0.16-2 garuda-update-1.3.1-1 harfbuzz-3.1.1-1
harfbuzz-icu-3.1.1-1 lib32-harfbuzz-3.1.1-1 nerd-fonts-fantasque-sans-mono-2.1.0-3
perl-uri-5.10-1 python-peewee-3.14.7-1 tracker3-3.2.1-1 wine-6.21-1 xorg-xwayland-21.1.3-1
Total Installed Size: 513.61 MiB
Net Upgrade Size: -0.52 MiB
garuda-update-1.3.1-1-any 3.6 KiB 4.34 KiB/s 00:01 [-------------------------------------] 100%
(12/12) checking keys in keyring [-------------------------------------] 100%
(12/12) checking package integrity [-------------------------------------] 100%
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package)
╭─[email protected] in ~ took 1m17s
One thing i would like to metion that , when i tried to remove the file mentioned in error then it showed me this:
[🔴] × rm /var/cache/pacman/pkg/garuda-update-1.3.1-any.pkg.tar.zst
rm: cannot remove '/var/cache/pacman/pkg/garuda-update-1.3.1-any.pkg.tar.zst': No such file or directory
╭─[email protected] in ~ took 4ms
it says file is not there !
Please help me , it's really causing me a heart attack because i have an online class after an hour , Thanks in advance!
inxi -Fza
╭─[email protected] in ~ took 2s
╰─λ inxi -Fza
System: Kernel: 5.14.15-1-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule
root=UUID=065222f3-c1bc-44ba-b8e7-df391a8ff7b0 rw [email protected] quiet splash
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
nouveau.modeset=0 sysrq_always_enabled=1
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland vt: 2 dm: SDDM
Machine: Type: Laptop System: Dell product: Inspiron 7570 v: N/A serial: <filter> Chassis: type: 10
Mobo: Dell model: 06K08K v: A00 serial: <filter> UEFI: Dell v: 1.16.0 date: 02/17/2020
Battery: ID-1: BAT0 charge: 24.1 Wh (100.0%) condition: 24.1/42.0 Wh (57.4%) volts: 12.9 min: 11.4
model: Samsung SDI DELL CYMGM79 type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32012
Speed: 1266 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 1266 2: 1486 3: 1385 4: 1446 5: 1168
6: 1235 7: 1227 8: 1324
Graphics: Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 1bcf:28c1 class-ID: 0e02
Display: wayland server: X.Org 1.21.1.2 compositor: kwin_wayland driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa display-ID: :1 screens: 1
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.14.15-1-cacule running: yes
Sound Server-5: PipeWire v: 0.3.39 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 03:00.0 chip-ID: 8086:095a
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: Samsung GT-I9070 (network tethering USB debugging enabled) type: USB driver: rndis_host
v: kernel bus-ID: 1-2:6 chip-ID: 04e8:6864 class-ID: 0a00 serial: <filter>
Device-2: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
chip-ID: 8087:0a2a class-ID: e001
Report: ID: hci0 rfk-id: 1 state: up address: <filter>
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Drives: Local Storage: total: 1.14 TiB used: 26.57 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: SDM3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 SATA 256GB size: 238.47 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: L003 scheme: GPT
Partition: ID-1: / raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 26.57 GiB (2.9%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 566 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 26.57 GiB (2.9%) fs: btrfs
ID-4: /var/log raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 26.57 GiB (2.9%) fs: btrfs
ID-5: /var/tmp raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 26.57 GiB (2.9%) fs: btrfs
ID-1: swap-1 type: zram size: 7.51 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2595
Info: Processes: 273 Uptime: 1h 33m wakeups: 7 Memory: 7.51 GiB used: 3.32 GiB (44.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1411 lib: 427 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: alacritty inxi: 3.3.08
╰─λ
