Garuda Update issues
Good Evening everyone Please forgive any breaches or protocol First time with an actual Issue I cant fix…
For the past four day I have been unable to update my system, I have tried Command line, Add/remove and octopi to attempt an up getting the same problem. Also reset keyrings and Mirrors even reset repositories
If it a Noob problem I ask forgiveness but I’m starting to run out of options
Attaching a screen shot of what I get and I’m still Noob enough to know when I’m out of my depth,
Thank you
Doug True
Hopefully someone can help.
Sorted it turned out somehow some of my Repositories where turned off and the computer was looking for them, had to enable all the repos listed and it worked…
Thanks for your help
Use
garuda-update
in terminal, always.
Problem is solved.
Please, use forum search first.
Another one.
Please, no pictures from Terminal.
Images can be read worse, are not searchable and copyable for further search.
