True
might be because of another app
I deinstalled them all from the last days
but unfortunately they left remnantsā¦
That\s why the idea to fix this replacements that cause withdrawal of users, is a very good one, SGS
and beacause i am a high level support by experince, my 2 c are:
central aprrovals of higher level libs before they go in action
warnings when the apps install a higher version. a lot of hypoteses here.
automation of fixing such depndancy higher-lower problems, with question on installations.
makes sense, SGS?
you see, i can be useful even not with IDK at the momentā¦
Back to topic please.
Please do not post here in the forum, like in chat forums like Telegram. As long as no one has responded to your post, you can edit your post.
This gnome stuff usually comes with the installation of some game launcher`s etc on the system.
Repeat the system update and post the complete output:
garuda-update
@Duke187,
Snapper had too new snapshot, so this did not work.
garuda-update remote reinstall helped!
I had to run it 3 times. First time it stopped in the middle. On the second, it offered to remove some broken packages.
On the third time it reinstalled everything.
Thank you very much for being so helpful!
Good luck!
