Just started getting this error this morning when running garuda-update. Any ideas?
garuda is up to date
cachyos-v3 is up to date
cachyos-core-v3 is up to date
cachyos-extra-v3 is up to date
cachyos is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
warning: hwinfo-23.3-1.1 is up to date -- reinstalling
warning: btrfs-assistant: local (2.1.1-1.2) is newer than cachyos (2.1.1-1)
warning: ckbcomp: local (1.232-1) is newer than cachyos (1.230-1)
warning: find-the-command-git: local (2.0.1.r0.gfecba1a-1.1) is newer than cachyos (2.0.r2.gfecba1a-1)
warning: kf6-servicemenus-rootactions: local (1.1.0-5) is newer than chaotic-aur (1.1.0-1)
warning: nyrna: local (2.24.0-1.5) is newer than chaotic-aur (2.24.0-1)
warning: paru: local (2.0.4-1.1) is newer than cachyos (2.0.4-1)
warning: qt-sudo: local (2.0.1-1.1) is newer than cachyos (2.0.1-1)
resolving dependencies...
:: unable to satisfy dependency 'libx86emu=3.5' required by hwinfo
Kernel: 6.13.5-2-cachyos arch: x86_64 bits: 64 compiler: clang v: 19.1.7
root=UUID=2d67dc72-6c9d-455a-96b7-1ea1a26c59da rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop System: Gigabyte product: X570 I AORUS PRO WIFI v: -CF
Mobo: Gigabyte model: X570 I AORUS PRO WIFI serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F39d
date: 09/02/2024
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3599 min/max: 550/4550 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3599 2: 3599 3: 3599
4: 3599 5: 3599 6: 3599 7: 3599 8: 3599 9: 3599 10: 3599 11: 3599 12: 3599
13: 3599 14: 3599 15: 3599 16: 3599 bogomips: 108805
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Tul / PowerColor driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-3
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 0c:00.0 chip-ID: 1002:744c
Screen-1: 0 s-res: 6000x1440 s-dpi: 96 s-size: 1587x381mm (62.48x15.00")
s-diag: 1632mm (64.26")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: Dell S2716DG
serial: <filter> built: 2017 res: N/A dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-3 mapped: DisplayPort-2 pos: primary,left
model: Dell AW3420DW serial: <filter> built: 2019 res: N/A dpi: 109
gamma: 1.2 size: 798x335mm (31.42x13.19") diag: 865mm (34.1") modes:
max: 3440x1440 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.0-cachyos1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 19.1.7 DRM 3.61 6.13.5-2-cachyos) device-ID: 1002:744c
memory: 19.53 GiB unified: no
API: Vulkan v: 1.4.304 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: N/A device-ID: 1002:744c
bus-ID: 0c:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-4.3.1.4:9 chip-ID: 0c76:161e class-ID: 0300
Device-3: Creative Sound Blaster X3
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:4 chip-ID: 041e:3264
API: ALSA v: k6.13.5-2-cachyos status: kernel-api with: aoss
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 8087:0029
Local Storage: total: 1.84 TiB used: 765.67 GiB (40.6%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN850 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 613200WD temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: PCIe SSD size: 953.87 GiB
tech: SSD serial: <filter> fw-rev: ECFM12.2 temp: 32.9 C scheme: GPT
used: 765.64 GiB (82.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
used: 31.9 MiB (10.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
System Temperatures: cpu: 41.5 C mobo: 39.0 C gpu: amdgpu temp: 40.0 C
mem: 50.0 C
Fan Speeds (rpm): fan-1: 0 gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.27 GiB used: 5.99 GiB (19.2%)
Processes: 413 Power: uptime: 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1888 libs: 552 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.0 running-in: konsole inxi: 3.3.37
System install date: 2024-09-27
Last full system update: 2025-03-05
