Does anyone know why if i use an arch linux mirror as build_mirror in the tools, at the end i get a mirrorlist with all Servers commented like this: #Server=http://......
That's just how Arch ships their full mirrorlists. You are supposed to uncomment the ones relevant to you. I recommend using the update command alias, which uses reflector to simply give you the fastest 5 mirrors.
Ok thx, should i have to edit my tools or just the mirrorlist file? I know about reflector but don' t know how to use it in my tools.
