Garuda System Settings Shell Changes Point to Incorrect Locations
Hello,
I wasn’t sure where to report this bug, so I’m reporting it here.
First of all, I just installed Garuda Dr460nized and it’s an absolutely beautiful way to run Arch Linux, so props there.
I was checking out the System Maintenance app and I must say compared to OpenMandriva’s and OpenSuse’s, this one is by the far the nicest. However, I went to change my shell under System settings and discovered that all of the shells are pointed to /usr/sbin/, when they are actually located in /usr/bin/, or in the case of BASH, /bin/bash. The first time I made the change, I didn’t really read it (I know, my fault) and found myself unable to login as my user. Thankfully I was able to login as root and change the shell manually.
Output for BASH:
+ set -e
++ which bash
+ chsh -s /usr/sbin/bash nymusicman
chsh: Warning: "/usr/sbin/bash" is not listed in /etc/shells.
Changing shell for nymusicman.
Shell changed.
+ echo 'Shell changed.'
Shell changed.
Output for Fish:
+ set -e
++ which fish
+ chsh -s /usr/sbin/fish nymusicman
chsh: Warning: "/usr/sbin/fish" is not listed in /etc/shells.
Shell changed.
Shell changed.
Kernel: 6.14.4-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=a4ddf9e4-3bc7-4055-8b24-cad9e057f829 rw rootflags=subvol=@
quiet resume=UUID=701d964f-57d0-4c5f-9ae6-1930fa9efc43 loglevel=3 ibt=off
Type: Mini-pc System: AZW product: SER8 v: N/A serial: <superuser required>
Chassis: type: 35 serial: <superuser required>
Mobo: AZW model: SER8 v: V10 serial: <superuser required> part-nu: 75
uuid: <superuser required> UEFI: American Megatrends LLC.
v: HPT.8xxx.SER8.V029.P8C0M0C15.13.Link date: 02/21/2025
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
Info: model: AMD Ryzen 7 8745HS w/ Radeon 780M Graphics bits: 64
process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
microcode: 0xA705206
Speed (MHz): avg: 1419 min/max: 400/4966 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1419 2: 1419 3: 1419
4: 1419 5: 1419 6: 1419 7: 1419 8: 1419 9: 1419 10: 1419 11: 1419 12: 1419
13: 1419 14: 1419 15: 1419 16: 1419 bogomips: 121370
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1 off: HDMI-A-1 empty: DP-2,
DP-3, DP-4, DP-5, DP-6, Writeback-1 bus-ID: 65:00.0 chip-ID: 1002:1900
class-ID: 0300 temp: 30.0 C
Monitor-1: DP-1 model: Acer R240HY serial: <filter> built: 2016 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 93 gamma: 1.2
Monitor-2: HDMI-A-1 model: ARZOPA serial: <filter> built: 2016
res: 1920x1080 dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.4-arch1.1
phoenix LLVM 19.1.7 DRM 3.61 6.14.4-zen1-2-zen) device-ID: 1002:1900
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV PHOENIX) driver: mesa radv v: 25.0.4-arch1.1
device-ID: 1002:1900 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
v: 25.0.4-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 65:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: 65:00.5 chip-ID: 1022:15e2 class-ID: 0480
bus-ID: 65:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Texas Instruments PCM2704 16-bit stereo audio DAC
lanes: 1 mode: 1.1 bus-ID: 5-1.4:5 chip-ID: 08bb:2704 class-ID: 0300
Device-5: Realtek USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 7-1.1.4:11 chip-ID: 0bda:4009 class-ID: 0300
API: ALSA v: k6.14.4-zen1-2-zen status: kernel-api tools: N/A
speed: 5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8125
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029
Device-2: Realtek driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-1.1:3 chip-ID: 0bda:a729 class-ID: e001
Report: ID: hci2 rfk-id: 4 state: up address: <filter> bt-v: 5.1 lmp-v: 10
status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 931.51 GiB used: 21.35 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 26.9 C
ID-1: / raw-size: 901.32 GiB size: 901.32 GiB (100.00%)
used: 21.35 GiB (2.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 901.32 GiB size: 901.32 GiB (100.00%)
ID-4: /var/log raw-size: 901.32 GiB size: 901.32 GiB (100.00%)
ID-5: /var/tmp raw-size: 901.32 GiB size: 901.32 GiB (100.00%)
ID-1: swap-1 type: partition size: 29.9 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 27.17 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.8 C mobo: 35.5 C gpu: amdgpu temp: 31.0 C
Memory: total: 28 GiB available: 27.18 GiB used: 4.58 GiB (16.9%)
Processes: 406 Power: uptime: 16m states: freeze,mem,disk suspend: s2idle
image: 10.86 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1547 libs: 395 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date:     2025-04-30
Last full system update: 2025-05-01
Huh…that’s an odd one. :thinking:
As far as I can tell, the application is not hardcoded to use /usr/sbin; it seems to use which just like the output says. I’m not sure, but I think this is where it is coming from: src/app/task-manager/os-interact.service.ts · main · Garuda Linux 🦅 / Applications / Reliable Assistant for Native Installations · GitLab
    const shell = this.shell();
    if (shell !== null && shell !== this.currentShell()) {
      script_services += `
            set -e
            chsh -s $(which ${shell.name}) ${this.configService.state().user}
            echo "Shell changed."
The weird thing is, which doesn’t give me /usr/sbin if I just run it straight in the terminal.
❯ which bash
/usr/bin/bash
❯ which fish
/usr/bin/fish
There must be something specific to how Rani handles this causing which to come up with /usr/sbin. :face_with_monocle:
@dr460nf1r3, can you take a look when you have a chance? It may have to wait until after finals week though! :face_with_peeking_eye:
From a quick look, it must be PATH being different in Rani job executions. Which leads me to Tauri’s shell plugin maybe causing it (it is used to spawn the bash executions).
Can likely fix it by providing it explicitly without?
But yeah, I should be learning right now, ahaha. God-damn it, I’ve never been disciplined or good at that, I’m much better at learning by doing :sweat_smile:
I try to keep track of all the to-dos, but in case I forget about something, feel free to note this down so I can take a look at everything once the time arrives :slight_smile: thank you!
:speak_no_evil_monkey:
i booted live iso and fixed somehow few years ago nice one ;)(used xterm) :wink:
