Garuda-System-Maintenance - failing Hotfix and keyring update
Hello,
The Garuda System Maintenance tool displays an Update Keyring and Force Hotfix Update. When I click on these two options, the respective update fails. What is the reason, and how can I fix it?
Thank you in advance for your help.
Inxi:
  Kernel: 6.15.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
    root=UUID=234e0b9d-12ef-4219-a044-9de9a4c49e6f rw rootflags=subvol=@ quiet loglevel=3 ibt=off
  Desktop: GNOME v: 48.3 tk: GTK v: 3.24.49 wm: gnome-shell tools: gsd-screensaver-proxy dm: GDM
    v: 48.0 Distro: Garuda base: Arch Linux
  Type: Server System: GEEKOM product: IT13 v: N/A serial: <superuser required>
  Mobo: N/A model: IT13 serial: <superuser required> part-nu: GEEKOM IT13
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.19 date: 08/09/2024
  Info: model: 13th Gen Intel Core i9-13900HK bits: 64 type: MST AMCP arch: Raptor Lake
    gen: core 13 level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6
    model-id: 0xBA (186) stepping: 2 microcode: 0x4128
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2 st: 8 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB L2: 11.5 MiB
    desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/5200:5400:4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400
    11: 400 12: 400 13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400
    bogomips: 119807
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] driver: i915 v: kernel alternate: xe arch: Xe
    process: Intel 7 (10nm) built: 2022+ ports: active: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:a7a0 class-ID: 0300
  Device-2: Dell Integrated_Webcam_5M_IR driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-6.4:6 chip-ID: 413c:c01d class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 compositor: gnome-shell
    driver: gpu: i915 display-ID: 0
  Monitor-1: DP-2 model: Dell S2422HZ serial: <filter> built: 2022 res: 1920x1080 dpi: 93
    gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080
    min: 720x400
  Monitor-2: HDMI-A-2 model: BenQ G2420HDBL serial: <filter> built: 2010 res: 1920x1080 dpi: 92
    gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080
    min: 720x400
  API: Vulkan v: 1.4.321 layers: 9 device: 0 type: integrated-gpu name: Intel Iris Xe Graphics
    (RPL-P) driver: mesa intel v: 25.1.6-arch1.1 device-ID: 8086:a7a0 surfaces: N/A device: 1
    type: cpu name: llvmpipe (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.6-arch1.1 (LLVM
  Info: Tools: api: vulkaninfo x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Raptor Lake-P/U/H cAVS driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
  Device-2: Dell S2422HZ driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6.3:5 chip-ID: 413c:c01b class-ID: 0300
  API: ALSA v: k6.15.7-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse status: active
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter vendor: AzureWave
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 56:00.0 chip-ID: 14c3:7922
  IF: wlp86s0 state: up mac: <filter>
  Device-2: Intel Ethernet I226-V driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: N/A bus-ID: 57:00.0 chip-ID: 8086:125c class-ID: 0200
  IF: enp87s0 state: down mac: <filter>
  IF-ID-1: br10 state: down mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-10:4 chip-ID: 13d3:3585 class-ID: e001 serial: <filter>
  Local Storage: total: 2.75 TiB used: 667.15 GiB (23.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PGP41024N-A0 size: 953.87 GiB
    fw-rev: ELFK7N.7 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD Sata III size: 1.82 TiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3A0
  ID-1: / raw-size: 824.56 GiB size: 824.56 GiB (100.00%) used: 44.67 GiB (5.4%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%) used: 81.3 MiB (27.5%) fs: vfat
  ID-3: /home raw-size: 824.56 GiB size: 824.56 GiB (100.00%) used: 44.67 GiB (5.4%) fs: btrfs
  ID-4: /var/log raw-size: 824.56 GiB size: 824.56 GiB (100.00%) used: 44.67 GiB (5.4%) fs: btrfs
  ID-5: /var/tmp raw-size: 824.56 GiB size: 824.56 GiB (100.00%) used: 44.67 GiB (5.4%) fs: btrfs
  ID-1: swap-1 type: zram size: 31.03 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
  System Temperatures: cpu: 48.0 C mobo: N/A
  Memory: total: 32 GiB available: 31.03 GiB used: 6.36 GiB (20.5%)
  Processes: 433 Power: uptime: 15m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.39 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical
  Packages: 1499 pm: pacman pkgs: 1492 libs: 470 tools: pamac,paru pm: flatpak pkgs: 7 Compilers:
    gcc: 15.1.1 Client: Unknown Client: electron inxi: 3.3.38
Garuda (2.7.3-1):
  System install date:     2025-06-29
  Last full system update: 2025-07-19
  Failed units:            garuda-system-maintenance@keyring-hotfixes.service garuda-system-maintenance@keyring.service
This should be fixed.
Maybe you could start checking
systemctl status garuda-system-maintenance@keyring-hotfixes.service
systemctl status garuda-system-maintenance@keyring.service
You could also try a
garuda-update
Just in case (because there was a keyring update recently, and garuda-update would perform it)…
