Hello. In my new garuda sway install I can’t change my mouse for left hand. I am new user of Linux… I need help please
Please always provide your system specs with the output of:
(see topic template).
Also search on the internet.
For example I see that the package input-remapper-git in the Chaotic-AUR could fit your needs (otherwise I’m afraid it could be a matter of libinput configuration, a bit more complicated).
You can install it with:
sudo pacman -S input-remapper-git
You can enable left-handed mode directly in the Sway config.
sway-input(5) — Arch manual pages
input left_handed enabled|disabled
Enables or disables left handed mode for specified input device.
If you are using a mouse, you can use pointer as the input type.
~/.config/sway/config.d/input
input type:pointer {
left_handed enabled
Be sure to reload your Sway config after you add that to your config.
I hope that helps, welcome to the community @zembra. ![]()
my -inxi is `Preformatted text`'System:
root=UUID=fe1c663f-271b-426b-9130-6ed601a8b6d3 rw rootflags=subvol=@
Desktop: Sway v: 0.5 with: waybar tools: swayidle avail: gtklock vt: 1
lm: greetd Distro: Garuda base: Arch Linux
Type: Desktop System: Gigabyte product: H110M-H v: N/A
Mobo: Gigabyte model: H110M-H-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F24 date: 04/11/2018
Info: model: Intel Core i3-7100 bits: 64 type: MT MCP arch: Kaby Lake
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 31199
Device-1: Intel HD Graphics 630 vendor: Gigabyte driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-1,HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5912
Display: wayland server: Xwayland v: 24.1.6 compositor: Sway v: 0.5
driver: gpu: i915 d-rect: 3840x1080 display-ID: 1
Monitor-1: DP-1 pos: primary,left model: Philips PHL 246V5
serial: <filter> built: 2019 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24")
Monitor-2: HDMI-A-1 pos: right model: Philips 244E serial: <filter>
built: 2011 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 25.1.1-arch1.1
device-ID: 8086:5912 surfaces: N/A device: 1 type: cpu name: llvmpipe
Info: Tools: api: vulkaninfo wl: kanshi, swaymsg, wdisplays x11: xprop
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
API: ALSA v: k6.14.6-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5.55 TiB used: 7.45 GiB (0.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SKC6002048G
size: 1.86 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0113 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Patriot model: P220 2048GB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 215a scheme: GPT
model: WD Blue SA510 2.5 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 09WD
ID-1: / raw-size: 1.06 TiB size: 1.06 TiB (100.00%) used: 7.44 GiB (0.7%)
fs: btrfs dev: /dev/sdb5 maj-min: 8:21
used: 12.1 MiB (2.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 1.06 TiB size: 1.06 TiB (100.00%)
used: 7.44 GiB (0.7%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 1.06 TiB size: 1.06 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.06 TiB size: 1.06 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
System Temperatures: cpu: 32.0 C mobo: N/A
Memory: total: 16 GiB available: 15.5 GiB used: 3.73 GiB (24.1%)
Processes: 212 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1141 libs: 356 tools: pacseek,paru,yay
Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
running-in: foot inxi: 3.3.38
System install date: 2025-05-22
Last full system update: 2025-05-22
Thnks for the input-remapper. I had found it in indernet and had installed before you wrote me this as help.. I am afraid I can’t use it because I don’t know the function of it. I made on “Input” two buttons but the program says “Missing macro or key”…
when I write ~/.config/sway/config.d/input my pc write fish: Unknown command. '/home/bib/.config/sway/config.d/input' exists but is not an executable file.
Please post your complete garuda-inxi, the current one is not complete (the last line is missing). Thank you. ![]()
You have to open the file with an editor, for example Micro.
micro ~/.config/sway/config.d/input
If you are using Micro, paste in the new lines with Ctrl+v, save the file with Ctrl+s, exit Micro with Ctrl+q, then reload your Sway config with Mod+Shift+C and test it out.
Thank you very much. The problem has been solved…Very good work … ![]()
