Garuda Sway grub
:warning: Missing information requested in the template may result in not receiving assistance :warning:
Issue still unresolved? Then:
  • ONE issue per topic.
  • Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>), or put three tildes (~) above and below the text
Installed Garuda Sway on HD /dev/sda2. (/dev/sda1 for EFI!) Have also installed EndevourOS LXQT on /dev/sda3. Both are in grub.cfg but only Garuda Sway is showing. How to boot EndeavourOS LXAT? Thank you for any hint.
Post also
lsblk -f
cat /etc/fstab
or ask @ ptr1337 :wink: Now I’ve mixed up the distributions.
