Pretty new Garuda/Arch user. I've been working with it for a bit over a month. I went a few days (~ week) without taking updates.
I went to do so, after installing the updates it hangs up with a blank screen with just a blinking cursor. After letting it sit for 6 hours thinking it would work itself out, I hit 'ctrl-alt-delete' and I see the 'watchdog time out' thing (I never got a picture of what it said specifically). It restarts and then it hangs up saying it's loading the Ram Disk. I've let it sit for a few hours hoping it would work itself out but to no avail.
I've just been restoring to the last good snap shot. Anything I should try? Should I try applying individual patches and updates? Should I wait until there is a larger update which might overwrite what may be hanging up my system? Thank you for any help and let me know if there are other things I need to dig into or read up on that could help.
My Garuda-inxi from the snapshot before I stopped being able to boot.
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0f81bc0d-8f5f-4647-a6bb-7ffc445612f0 rw rootflags=subvol=@
resume=UUID=00336908-7353-4291-b22c-3f74eef8c60d loglevel=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock
Mobo: ASUSTeK model: PRIME B450M-A II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3202
date: 06/16/2021
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3551 high: 3600 min/max: 1400/4268 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3017 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600
12: 3600 bogomips: 86238
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
driver: nvidia v: 470.141.03 alternate: nouveau,nvidia_drm non-free:
series: 470.xx+ status: legacy-active (EOL~2023/24) arch: Fermi 2
code: GF119/GK208 process: TSMC 28nm built: 2010-16 pcie: gen: 2
speed: 5 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3200x1080 s-dpi: 92 s-size: 883x292mm (34.76x11.50")
s-diag: 930mm (36.62")
Monitor-1: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: VGA-0 pos: right res: 1280x1024 hz: 60 dpi: 96
size: 338x270mm (13.31x10.63") diag: 433mm (17.03") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA
470.141.03 direct render: Yes
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 1-3:2 v: kernel pcie: chip-ID: 0d8c:0014
class-ID: 0300 gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6 chip-ID: 1022:15e3
Device-4: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0 chip-ID: 10ec:8168
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 4.55 TiB used: 92.32 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-9YN162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC62
ID-1: / raw-size: 3.62 TiB size: 3.62 TiB (100.00%) used: 92.32 GiB (2.5%)
ID-3: /home raw-size: 3.62 TiB size: 3.62 TiB (100.00%) used: 92.32 GiB
(2.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 3.62 TiB size: 3.62 TiB (100.00%) used: 92.32
GiB (2.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 3.62 TiB size: 3.62 TiB (100.00%) used: 92.32
ID-1: swap-1 type: zram size: 15.42 GiB used: 1024 KiB (0.0%)
ID-2: swap-2 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 51%
Processes: 335 Uptime: 24m wakeups: 0 Memory: 15.42 GiB used: 7.43 GiB
(48.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1997 libs: 547
Garuda (2.6.8-1):
System install date: 2022-09-16
Last full system update: 2022-10-11
Is partially upgraded: Yes
