So in the latest Garuda Gamer OS, after you setup everything and update everything in order to continue using the Garuda Setup Assistant, after the update is done, Garuda setup assistant keeps saying it failed, which also blocks me from upgrading to Ultimate (so i can install Garuda Gamer apps).
Screenshot:
Update setup
[sudo] password for gt2g:
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 2045,7 KiB 1311 KiB/s 00:02 [------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda 95,8 KiB 43,7 KiB/s 00:02 [------------------------------------] 100%
core 157,2 KiB 146 KiB/s 00:01 [------------------------------------] 100%
extra 1746,9 KiB 487 KiB/s 00:04 [------------------------------------] 100%
community 7,2 MiB 929 KiB/s 00:08 [------------------------------------] 100%
multilib 166,0 KiB 130 KiB/s 00:01 [------------------------------------] 100%
chaotic-aur 2045,7 KiB 557 KiB/s 00:04 [------------------------------------] 100%
spawn pacman -Su
warning: libnm: local (1.40.4-1) is newer than extra (1.40.2-1)
warning: networkmanager: local (1.40.4-1) is newer than extra (1.40.2-1)
warning: nm-cloud-setup: local (1.40.4-1) is newer than extra (1.40.2-1)
there is nothing to do
Checking for plugin updates
Nothing to install / update
System updated! 🐧
Press enter to exit
ive updated like 5 times, what should i do?
