Issue:
garuda-settings-manager will not load.
Error:
╭─jedi@jedi in ~ as 🧙 took 9ms
╰─λ garuda-settings-manager
garuda-settings-manager: error while loading shared libraries: libhd.so.22: cannot open shared object file: No such file or directory
Troubleshooting:
remove/reinstall package
reboot system
╰─λ sudo pacman -Syu
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
there is nothing to do
╭─jedi@jedi in ~ as 🧙 took 5s
╰─λ pacman -Q garuda-settings-manager
garuda-settings-manager 1.0.2-2
System Information:
Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=41ba4255-afca-4db8-860f-1f050aa76026 rw rootflags=subvol=@
quiet rd.luks.uuid=371fe326-f0ea-458f-9627-173095a01c7c quiet
Desktop: Cinnamon v: 5.8.3 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Micro-Star product: GP63 Leopard 8RD v: REV:1.0
Mobo: Micro-Star model: MS-16P6 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16P6IMS.109 date: 05/22/2019
ID-1: BAT1 charge: 40.0 Wh (98.5%) condition: 40.6/53.4 Wh (76.0%)
volts: 11.9 min: 10.9 model: MSI Corp. MS-16P6 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
Plus serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1966 high: 2200 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2200 3: 800
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 52799
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: HDMI-A-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 535.54.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:7 chip-ID: 5986:211b
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: primary model: NS-39D220NA16
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
size: 698x392mm (27.48x15.43") diag: 976mm (38.4") ratio: 16:9 modes:
max: 1360x768 min: 720x400
Monitor-2: eDP-1 note: disabled model: LG Display 0x0590 built: 2017
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8
address: <filter>
Local Storage: total: 2.75 TiB used: 1.5 TiB (54.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 model: SATA SSD size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 61.3 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: PSSD T7 Shield
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 538.55 GiB (57.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-371fe326-f0ea-458f-9627-173095a01c7c
ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C pch: 65.0 C mobo: N/A
Processes: 375 Uptime: 6m wakeups: 3 Memory: available: 31.19 GiB
used: 3.58 GiB (11.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1792 libs: 505 tools: gnome-software,octopi,pamac,paru,yay Shell: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
System install date: 2023-06-11
Last full system update: 2023-07-08
