Garuda-settings dont work
Hello, garuda-settings dont work. “error while loading shared libraries
>garuda-settings-manager
garuda-settings-manager: error while loading shared libraries: libhd.so.23: cannot open shared object file: No such file or directory
  Kernel: 6.12.24-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e93c39d4-7f1d-473a-b855-7c30deb309e1 rw rootflags=subvol=@
    with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
  Type: Desktop Mobo: Micro-Star model: H310M PRO-VH (MS-7B33) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.E0
    date: 07/10/2024
  Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
    model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
    bogomips: 44412
  Device-1: Intel Battlemage G21 [Arc B580] vendor: ASRock driver: xe
    v: kernel arch: Xe2 process: TSMC n4 (4nm) built: 2024+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 ports: active: HDMI-A-3 empty: DP-1, DP-2, DP-3,
    HDMI-A-1, HDMI-A-2, HDMI-A-4 bus-ID: 03:00.0 chip-ID: 8086:e20b
  Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3
    chip-ID: 1532:0e03 class-ID: 0102
  Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: xe
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99")
  Monitor-1: HDMI-A-3 mapped: HDMI-3 model: Philips PHL 241V8
    serial: <filter> built: 2030 res: N/A dpi: 93 gamma: 1.2
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (BMG G21)
    device-ID: 8086:e20b memory: 11.65 GiB unified: no
  API: Vulkan v: 1.4.309 layers: 12 device: 0 type: discrete-gpu name: Intel
    Graphics (BMG G21) driver: N/A device-ID: 8086:e20b surfaces: xcb,xlib
    device: 1 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
    gpu: nvidia-smi x11: xdpyinfo, xprop, xrandr
  Device-2: Intel vendor: ASRock driver: snd_hda_intel v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:e2f7
  Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.24-1-lts status: kernel-api tools: N/A
    lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0bda:8771
  Local Storage: total: 894.25 GiB used: 110.69 GiB (12.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37960G
    size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 62C3 scheme: GPT
  ID-1: / raw-size: 175.68 GiB size: 175.68 GiB (100.00%)
    used: 110.64 GiB (63.0%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
  ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
    used: 53.4 MiB (8.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 175.68 GiB size: 175.68 GiB (100.00%)
  ID-4: /var/log raw-size: 175.68 GiB size: 175.68 GiB (100.00%)
  ID-5: /var/tmp raw-size: 175.68 GiB size: 175.68 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.69 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 6
  ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda7 maj-min: 8:7
  System Temperatures: cpu: 29.0 C pch: 50.0 C mobo: N/A
  Memory: total: 8 GiB available: 7.69 GiB used: 1.65 GiB (21.4%)
  Processes: 288 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.07 GiB services: upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Packages: 1306 pm: pacman pkgs: 1297 libs: 409 tools: octopi,pamac,paru
    pm: flatpak pkgs: 9 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish
    v: 4.0.2 running-in: xfce4-terminal inxi: 3.3.37
  System install date:     2025-03-17
  Last full system update: 2025-04-21
Please use the forum search first, the issue is known:
