Garuda seems to be resetting the home page every so often
garuda-inxi output:
r: schedutil cores: 1: 2200 2: 2201
3: 2200 4: 2200 5: 2201 6: 2200 7: 2200 8: 2200 9: 2201 10: 2201 11: 2201
12: 2201 bogomips: 52799
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: eDP-1
empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c20
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0408:a060 class-ID: 0e02 serial:
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1-1 mapped: eDP-1 model: AU Optronics built: 2018
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6")
OpenGL: renderer: NVIDIA GeForce GTX 1060/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.16.15-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
IF: wlp0s20f3 state: up mac:
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.1 chip-ID: 10ec:8168
IF: enp7s0f1 state: down mac:
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 3 state: up address:
Local Storage: total: 2.05 TiB used: 1.71 TiB (83.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW256G8
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: rev: 001C
temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
type: HDD rpm: 5400 serial: rev: SDM2 scheme: GPT
used: 57.52 GiB (24.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 87.0 C pch: 73.0 C mobo: N/A gpu: nvidia
temp: 70 C
Processes: 341 Uptime: 2h 18m wakeups: 1 Memory: 15.47 GiB
used: 3.71 GiB (24.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1819 lib: 560 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2021-12-29
Last full system update: 2022-03-18 ↻
Relevant software: tlp NetworkManager
I've looked for a while for a resolution to this, but have found nothing.
The OS seems to be resetting my homepage in FIrefox to https://start.garudalinux.org/
Can someone please tell me how to stop this from happening? I love this distro, but I'm going to have to move on if I can't get it to respect my choices of homepage, then I'm out, ya know?
What I know:
It happens after I restart my PC almost every time (but not always)
It happens after some updates
I can't pin down the update it happens on, so it may not be that.
Welcome to the forum.
Please post complete garuda-inxi between three ~ in first and last line.
Did you check the FireDragon settings, open previous windows and tabs?
Do not forget to reboot after your last full system update: 2022-03-18 ↻
User edited out the distro from garuda-inxi.
Obviously not a Garuda user.
Therefore thread binned. :wave:
Threats! Why do some resort to threatening a Linux distribution? Did it eat your firstborn? Forget to invite you to supper? Snub you at that oh-so important social event?
Does doing so send the distribution running in fear? Dodging traffic? Eating squirrels?
I have fired ex-wives for less. And if #3 doesn’t watch it? Phht!
I understand, little dude.
