Parts of the UI are just in russian for some reason and I can’t change it. I tried changing the language to english in SearX settings and applying it (after translating the apply button) but it just stays in russian.
Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1e0ad18c-0993-40e1-b5e4-31a3b75f8dad rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.H0
date: 09/21/2023
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 high: 3602 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3598 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3602 8: 3600 9: 3602 10: 3600 11: 3600
12: 3600 13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115190
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Gigabyte M27Q
serial: <filter> built: 2020 res: 2560x1440 dpi: 109 gamma: 1.2
size: 596x335mm (23.46x13.19") diag: 801mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.6-zen2-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 2972:0047 class-ID: fe01
API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.96 TiB used: 15.51 GiB (0.5%)
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
size: 232.97 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 15.51 GiB (0.8%)
used: 15.51 GiB (0.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 42.9 C mobo: N/A gpu: amdgpu temp: 44.0 C
mem: 44.0 C
Processes: 347 Uptime: 8m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 3.11 GiB (10.0%) Init: systemd v: 254
pm: pacman pkgs: 1672 libs: 471 tools: pamac,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2023-10-10
Last full system update: 2023-10-11
