Garuda Screen Problem
  Kernel: 5.19.6-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-anbox
    root=UUID=866e0b23-19e5-43ac-802b-ce0f5de6cac2 rw rootflags=subvol=@ quiet quiet splash
  Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: MONSTER product: ABRA A7 V12.5 v: N/A serial: <superuser required> Chassis:
    type: 10 serial: <superuser required>
  Mobo: MONSTER model: ABRA A7 V12.5 serial: <superuser required> UEFI: INSYDE v: 1.07.10TFB24
    date: 12/06/2021
  ID-1: BAT0 charge: 47.3 Wh (100.0%) condition: 47.3/47.2 Wh (100.4%) volts: 16.6 min: 14.4
    model: Notebook BAT type: Li-ion serial: <filter> status: full
  Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
    built: 2020 process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
  Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 480 KiB desc: d-6x48
    KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2697 high: 4155 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2851 2: 2700 3: 2740 4: 1759 5: 2761 6: 4155 7: 2937 8: 2700
    9: 894 10: 3293 11: 3576 12: 2004 bogomips: 64512
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: SW
    sequence
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK driver: i915 v: kernel
    arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: CLEVO/KAPOK driver: nvidia
    v: 515.65.01 alternate: nvidiafb,nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
    2022-07) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 4
    speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
  Device-3: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 04f2:b729
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 compositor: kwin_x11 driver: X:
    loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: i915
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0a15 built: 2021 res: 1920x1080 hz: 144
    dpi: 128 gamma: 1.2 size: 380x210mm (14.96x8.27") diag: 437mm (17.2") ratio: 16:9
    modes: 1920x1080
  OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7 direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  Sound Server-1: ALSA v: k5.19.6-xanmod1-1 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:1
4.3
    chip-ID: 8086:43f0 class-ID: 0280
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0026
  Local Storage: total: 465.76 GiB used: 17.11 GiB (3.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8 size: 465.76 GiB
    rev: P2CR048 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%) fs: btrfs
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 29.7 MiB (30.9%) fs: vfat
  ID-3: /home raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%) fs: btrfs
  ID-4: /var/log raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%)
    fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-5: /var/tmp raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%)
  ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
  System Temperatures: cpu: 53.0 C mobo: N/A
  Processes: 306 Uptime: 9m wakeups: 1 Memory: 15.42 GiB used: 3.81 GiB (24.7%) Init: systemd
  v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pacman: 1378 lib: 333
  Client: shell wrapper v: 5.1.16-release inxi: 3.3.20
Garuda (2.6.6-1):
  System install date:     2022-08-31
  Last full system update: 2022-09-05
  Failed units:            systemd-oomd.socket
When I try to take a screen recording, my screen appears like this. But I don't have any problem
Have you tried disabling the compositor?
Also try changing its settings.
Search also in the forum, e.g. (not limited to):
