Garuda Rani - preview releases and testing
What about missing linux kernel headers? Is this possible?
To those running the -git version, do you feel the application is stable enough to replace the current stable (non -git) version? If you’re not running it, feel free to give it a shot and five feedback too!
Using only the stable version since beginning. I haven’t tried everything down to the last detail, but it works like a charm.
Generally a great piece of work and in my opinion a real killer tool.
Many thanks to all who work on it :+1: :+1: :+1:
Both versions run stably here, as far as I’ve tested them.
The only noticeable difference is that in the git version, I don’t have to double-click the top window frame to display the resolution correctly.
So i can say that both are fine. The git Version is a tick faster and the other differences is with the password Session safe isnt exist but its not important for me as i have to type also the pw in terminals :wink:
Running git-version here and its fast and stable. Very nice umbrella of tools! :star_struck:
Wonder if it’s overkill to add a add-pending button for reboot system when you run updates? I always reboot after updates, maybe not always necessary but feels like a good habit.
yes i did have the same idea :wink:
2.0.0 is soon available! :slight_smile:
[2.0.0] - 2025-03-17
:rocket: Features
  • (taskmanagerservice) Massive rewrite of the task system including speedups
  • (window) Responsive window button states
  • (loadingservice) Use refcount on loading indicator
  • (font) Use system-ui
  • (init) Resize window to reasonable size when monitor is too small
  • Move parseArchWiki script to Typescript
  • (system-status) Report AUR updates too
  • (system-status) Support schedule AUR updates, update on task updates
  • Strip AUR functionality, we decided to not support it
  • (system-components) Expand with containers section
  • Menu bar “terminal” button glows actively when tasks are pending
  • (terminal) Only show buttons when needed/reasonable
:bug: Bug Fixes
  • (os-interact) Fix setting dns to default
  • (diagnostics) Disable logging symbol after loading full diagnostics
  • (system-status) Invalid update versions
  • (angular) Zoneless change detection complaining
  • (gamer) Some icons being improperly sized
  • (gaming) Missing pacakges, add script to check for missing ones
  • (theme) Light theme not working, wrong window buttons on the right
  • (window) Set reasonable menu breakpoint, set logicalSize dynamically
  • (dynamic-checkboxes) Ensure already enabled/installed packages are not disabled
  • Duplicated updates, duplicated logic
  • (systemd-services) Event reporting failure due to no output
  • Menu bar “terminal” button size changing when glow effect is active
:artist_palette: Styling
  • Declare types as types
:gear: Miscellaneous Tasks
  • Cleanup unused
  • Add package list check
  • Also check AUR packages
  • Fix missing pnpm, less verbose script
[1.3.1] - 2025-03-12
:bug: Bug Fixes
  • Set WEBKIT_DISABLE_COMPOSITING_MODE for NVIDIA GPUs
[1.3.0] - 2025-03-06
:bug: Bug Fixes
  • (package.json,cargo.toml) Cleanup required packages
  • (translation) Load translations before the application loads
  • (home) Utilize launch-terminal garuda-libs script for chroot
[1.2.0] - 2025-03-05
:rocket: Features
  • Allow confirmation-less app exit when there are no pending tasks.
  • (operation-manager) Do not store/restore pending operations when exiting app
  • (logs) Allow setting loglevel
:bug: Bug Fixes
  • (shell.nix) Fix nix build env
  • (style) Disable any kind of text selection
  • (diagnostics) Do not use garuda-inxi funstuff
  • (config,home) Fix excessive redraws, live system detection, angular change detection
  • More efficient file existence checks via plugin-fs
  • (status) Logs reporting update check failure when none are availble
  • (theme-handler) Use updateConfig method to set new setting
  • (xterm) Use computed signal to prevent wrong theme
:tractor: Refactor
  • (first-boot) Revamp first boot checks
  • (darkmode) Redo darkmode to be more consistent
  • (language-switcher) Redo language-switcher to be more consistent
  • (app) Pre-init config before rendering application
  • (app) More reliable menu/label setup, more reliable transloco
[1.1.0] - 2025-03-02
:rocket: Features
  • Run setup-assistant on first boot, relaunch after update
  • (gaming) Import new icons from gamer, placeholders update
[1.0.2] - 2025-03-02
:rocket: Features
  • (welcome) Don’t show status on live system
:bug: Bug Fixes
  • No max size, inform about errors, calamares not starting
[1.0.1] - 2025-03-02
:bug: Bug Fixes
  • User set to null, loglevel to info, skip mirrorlist by default
lol many rani updates i have today :grin:
ps. nice coloring on running task good work Nico :wink: and @TNE + Garuda Team :+1:
idk if someone uses Playonlinux as a Game Launcher but it works more fine in my case as with Lutris maybe a option to add to Rani too. its not a must have but worth a try for someone too. =)
That was meeeee
it is really good looking in 2.0
My Garuda Rani is blank, there is a Window but nothing is rendered in it :disappointed_face:
A restart didn’t help.
i
Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Type: Desktop Mobo: MSI model: A68HM-E33 V2 (MS-7721) v: 9.0
UEFI: American Megatrends v: 8.5 date: 11/01/2018
Info: model: AMD Athlon X4 860K bits: 64 type: MCP arch: Steamroller
level: v2 built: 2014 process: GF 28nm family: 0x15 (21) model-id: 0x30 (48)
stepping: 1 microcode: 0x6003106
L1: 256 KiB desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3717 min/max: 1700/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3717 2: 3717 3: 3717
4: 3717 bogomips: 29545
Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: PC Partner / Sapphire
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 34.0 C
Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:2
chip-ID: 046d:085e class-ID: 0102 serial: <filter>
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Dell S2721H serial: <filter>
built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 pos: right model: Dell S2721H serial: <filter>
built: 2022 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 460 Graphics
(radeonsi polaris11 ACO DRM 3.61 6.13.7-zen1-1-zen) device-ID: 1002:67ef
API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 460 Graphics (RADV POLARIS11) driver: N/A device-ID: 1002:67ef
Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon
RX 550 640SP / 560/560X] vendor: PC Partner / Sapphire
bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api tools: N/A
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Info: services: NetworkManager, sshd, systemd-timesyncd
Local Storage: total: 1.35 TiB used: 593.34 GiB (43.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: MU05 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240M500SSD1
model: WD10EALX-009BA0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1H15
used: 63.06 GiB (28.2%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 27.4 MiB (9.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
System Temperatures: cpu: 25.1 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1043
Memory: total: 16 GiB available: 15.57 GiB used: 4.6 GiB (29.6%)
Processes: 275 Power: uptime: 1h 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1696 libs: 431 tools: octopi,pacseek,paru
Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
System install date:     2024-08-28
Last full system update: 2025-03-18
Is it the stable or git package?
garuda/garuda-rani-git 2.1.0.r5.gfa8fa57-1 [0 B 33.75 MiB] [Installed]
can approve it after todays update is blank the git version :wink:
ps. i downgrade it back to 2.0.0. r4 version and its back on :wink:
sudo downgrade garuda-rani-git
Confirming blank after todays update from git version
I can also confirm this. Even if it sounds unbelievable coming from me…it’s not an nvidia issue. :face_with_open_eyes_and_hand_over_mouth:
old an new ver logs. amd gpu though.
2.0.0.r4.g90…
❯ garuda-rani
[2025-03-18][15:35:15][TRACE][webview:trace@tauri://localhost/main-LXUD7P2L.js:30745:17] Initializing ConfigService
[2025-03-18][15:35:15][TRACE][webview:trace@tauri://localhost/main-LXUD7P2L.js:30745:17] Loading on
[2025-03-18][15:35:15][DEBUG][webview:debug@tauri://localhost/main-LXUD7P2L.js:30754:17] Saving config to: /home/elite/Distrobox-Arch-Home/.config/org.garudalinux.rani
[2025-03-18][15:35:15][ERROR][webview:error@tauri://localhost/main-LXUD7P2L.js:30781:17] Could not get code name
[2025-03-18][15:35:15][DEBUG][webview:debug@tauri://localhost/main-LXUD7P2L.js:30754:17] User elite, welcome!
[2025-03-18][15:35:15][TRACE][webview:trace@tauri://localhost/main-LXUD7P2L.js:30745:17] Active language: en
[2025-03-18][15:35:15][DEBUG][webview:debug@tauri://localhost/main-LXUD7P2L.js:30754:17] Filesystem type: overlay, is live
[2025-03-18][15:35:15][TRACE][webview:trace@tauri://localhost/main-LXUD7P2L.js:30745:17] Setting language to en
[2025-03-18][15:35:15][TRACE][webview:trace@tauri://localhost/main-LXUD7P2L.js:30745:17] Setting darkMode to true
[2025-03-18][15:35:15][TRACE][webview:trace@tauri://localhost/main-LXUD7P2L.js:30745:17] Setting autoStart to false
[2025-03-18][15:35:15][TRACE][webview:trace@tauri://localhost/main-LXUD7P2L.js:30745:17] Setting firstBoot to false
[2025-03-18][15:35:15][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Loaded 4 settings from store
[2025-03-18][15:35:15][ERROR][webview:error@tauri://localhost/main-LXUD7P2L.js:30781:17] Enabled dark mode via effect
[2025-03-18][15:35:16][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Executing bash code: systemctl list-units --type service --full --output json --no-pager
[2025-03-18][15:35:16][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Executing bash code: systemctl --user list-units --type service --full --output json --no-pager
[2025-03-18][15:35:16][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Executing bash code: pacman -Qq
[2025-03-18][15:35:16][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Executing bash code: groups elite | cut -d ' ' -f 3-
[2025-03-18][15:35:16][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Executing bash code: cat /etc/resolv.conf | grep nameserver | head -n 1 | cut -d " " -f 2
[2025-03-18][15:35:16][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Executing bash code: basename $(/usr/bin/getent passwd $USER | awk -F':' '{print $7}')
[2025-03-18][15:35:16][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Executing bash code: cat /etc/hosts | grep -A1 "Blocked domains" | awk '/Blocked domains/ { print $NF }'
[2025-03-18][15:35:20][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Close requested, no action is running
[2025-03-18][15:35:20][INFO][webview:info@tauri://localhost/main-LXUD7P2L.js:30763:16] Shutting down
2.1.0.r5.gfa…
❯ garuda-rani
[2025-03-18][15:35:39][TRACE][webview:trace@tauri://localhost/main-M6T7OPNO.js:30745:17] Initializing ConfigService
[2025-03-18][15:35:39][TRACE][webview:trace@tauri://localhost/main-M6T7OPNO.js:30745:17] Loading on
[2025-03-18][15:35:39][DEBUG][webview:debug@tauri://localhost/main-M6T7OPNO.js:30754:17] Saving config to: /home/elite/Distrobox-Arch-Home/.config/org.garudalinux.rani
[2025-03-18][15:35:39][ERROR][webview:error@tauri://localhost/main-M6T7OPNO.js:30781:17] Could not get code name
[2025-03-18][15:35:39][DEBUG][webview:debug@tauri://localhost/main-M6T7OPNO.js:30754:17] User elite, welcome!
[2025-03-18][15:35:39][TRACE][webview:trace@tauri://localhost/main-M6T7OPNO.js:30745:17] Active language: en
[2025-03-18][15:35:39][DEBUG][webview:debug@tauri://localhost/main-M6T7OPNO.js:30754:17] Filesystem type: overlay, is live
[2025-03-18][15:35:39][TRACE][webview:trace@tauri://localhost/main-M6T7OPNO.js:30745:17] Setting language to en
[2025-03-18][15:35:39][TRACE][webview:trace@tauri://localhost/main-M6T7OPNO.js:30745:17] Setting darkMode to true
[2025-03-18][15:35:39][TRACE][webview:trace@tauri://localhost/main-M6T7OPNO.js:30745:17] Setting autoStart to false
[2025-03-18][15:35:39][TRACE][webview:trace@tauri://localhost/main-M6T7OPNO.js:30745:17] Setting firstBoot to false
[2025-03-18][15:35:39][INFO][webview:info@tauri://localhost/main-M6T7OPNO.js:30763:16] Loaded 4 settings from store
and yes i have a full garuda distrobox setup :wink:
core is up to date
 extra                                                         7.7 MiB  3.96 MiB/s 00:02 [####################################################] 100%
 garuda                                                       52.8 KiB  67.5 KiB/s 00:01 [####################################################] 100%
 chaotic-aur                                                 638.8 KiB  1159 KiB/s 00:01 [####################################################] 100%
Funny thing, as expected, it had to do with translations. But this only happened in a deployed package and not while developing. Love such errors.
failed to open file at path: /usr/lib/garuda-rani/_up_/assets/i18n/en.json with error: No such file or directory (os error 2)
Edit: it was indeed a packaging issue. Will be fixed as soon as things finish compiling.
might be cause its a distrobox but
