Garuda Rani isn't booting on fresh Mokka install
Heyo, for some reason Rani isn’t showing up on boot. I have a fresh install of Mokka that I’m trouble-shooting.
I’ve tried running it through both the GUI and terminal (I didn’t recieve any feedback or errors when running in terminal) and it still doesn’t boot.
I’ve tried to re-install garuda-rani, but didn’t receive any errors or things of note and the issue persists.
I’ve searched around for possible direction here and on reddit, but the other posts about this topic have been less than helpful in my case.
ty for the assist. :3
garuda-inxi:
Kernel: 6.16.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=41062ba0-38d5-4815-8755-090266e9425f rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Garuda
Type: Desktop Mobo: ASRock model: B650M Pro RS serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 3.10
date: 10/24/2024
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4834 min/max: 427/5457 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4834 2: 4834 3: 4834
4: 4834 5: 4834 6: 4834 7: 4834 8: 4834 9: 4834 10: 4834 11: 4834 12: 4834
bogomips: 112593
Device-1: Intel Battlemage G21 [Arc B580] driver: xe v: kernel arch: Xe2
process: TSMC n4 (4nm) built: 2024+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1
ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3,
HDMI-A-4 bus-ID: 03:00.0 chip-ID: 8086:e20b class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASRock
empty: DP-4, DP-5, DP-6, HDMI-A-5, Writeback-1 bus-ID: 11:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 49.0 C
compositor: kwin_wayland driver: gpu: xe display-ID: 0
Monitor-1: DP-3 model: Acer ED343CUR V serial: <filter> built: 2023 res:
mode: 3440x1440 hz: 165 scale: 100% (1) dpi: 111 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 862mm (33.9") modes: max: 3440x1440
min: 720x400
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc B580 Graphics (BMG
G21) device-ID: 8086:e20b memory: 11.65 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: discrete-gpu name: Intel
Arc B580 Graphics (BMG G21) driver: mesa intel v: 25.2.1-arch1.2
device-ID: 8086:e20b surfaces: N/A device: 1 type: integrated-gpu name: AMD
v: 25.2.1-arch1.2 device-ID: 1002:164e surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 20.1.8 256 bits) driver: mesa llvmpipe
v: 25.2.1-arch1.2 (LLVM 20.1.8) device-ID: 10005:0000 surfaces: N/A
Device-1: Intel driver: snd_hda_intel v: kernel pcie: speed: Unknown
lanes: 63 link-max: gen: 1 speed: 2.5 GT/s bus-ID: 04:00.0
chip-ID: 8086:e2f7 class-ID: 0403
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:5
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.16.3-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.66 TiB used: 528 GiB (14.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FFD001T
lanes: 4 tech: SSD serial: <filter> fw-rev: SN16486 temp: 49.9 C
model: WD30EFRX-68EUZN0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
used: 16.13 GiB (1.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.43 GiB used: 272 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.8 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (rpm): cpu: 144 fan-2: 150 fan-3: 0
Memory: total: 32 GiB note: est. available: 30.43 GiB used: 4.45 GiB (14.6%)
Processes: 509 Power: uptime: 41m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1387 libs: 368 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.8.2-2):
System install date:     2025-08-25
Last full system update: 2025-08-26 ↻
This means it’s opening up when you start it manually (via start menu for example) ?
Your statement later confuses me. Please clarify.
If it’s not opening at all, please use --enable-logging as parameter when opening via console and post eventual output here.
If it doesn’t auto start, check ~/.config/autostart, is there a Rani desktop item?
Rani is not opening at all, regardless of method, apologies for the confusion.
I do not see any “Rani desktop” inside of ~/.config/autostart folder, just a file called initial-setup.sh which doesn’t contain any lines referring to rani that I can make out.
output of garuda-rani --enable-logging:
[3345:0826/232228.808275:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232228.808307:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 1 time(s)
ERROR [23:22:28.808]: Main - Child process gone: {
"type": "GPU",
"reason": "crashed",
"exitCode": 135,
"serviceName": "GPU"
[3345:0826/232229.149262:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232229.149271:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 2 time(s)
ERROR [23:22:29.149]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3345:0826/232229.477997:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232229.478005:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 3 time(s)
ERROR [23:22:29.478]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3345:0826/232229.770903:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232229.770912:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 4 time(s)
ERROR [23:22:29.771]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3345:0826/232230.065787:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232230.065795:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 5 time(s)
ERROR [23:22:30.066]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3345:0826/232230.363509:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232230.363520:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 6 time(s)
ERROR [23:22:30.363]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3345:0826/232230.507609:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232230.507617:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 7 time(s)
ERROR [23:22:30.507]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3345:0826/232230.655382:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232230.655392:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 8 time(s)
ERROR [23:22:30.655]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3345:0826/232230.799828:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3345:0826/232230.799839:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 9 time(s)
[3345:0826/232230.799850:FATAL:content/browser/gpu/gpu_data_manager_impl_private.cc:416] GPU process isn't usable. Goodbye.
fish: Job 1, 'garuda-rani --enable-logging' terminated by signal SIGILL (Illegal instruction)
Heya! What happens when you start Rani with DRI_PRIME=1 garuda-rani --enable-logging
Here’s the output:
[3357:0827/011557.630320:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011557.630344:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 1 time(s)
ERROR [01:15:57.630]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011558.013939:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011558.013948:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 2 time(s)
ERROR [01:15:58.014]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011558.419858:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011558.419868:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 3 time(s)
ERROR [01:15:58.420]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011558.707771:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011558.707782:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 4 time(s)
ERROR [01:15:58.708]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011559.007610:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011559.007627:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 5 time(s)
ERROR [01:15:59.007]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011559.297121:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011559.297131:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 6 time(s)
ERROR [01:15:59.297]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011559.424123:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011559.424133:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 7 time(s)
ERROR [01:15:59.424]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011559.568548:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011559.568557:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 8 time(s)
ERROR [01:15:59.568]: Main - Child process gone: {
"type": "GPU",
"exitCode": 135,
[3357:0827/011559.695080:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=135
[3357:0827/011559.695090:WARNING:content/browser/gpu/gpu_process_host.cc:1397] The GPU process has crashed 9 time(s)
[3357:0827/011559.695099:FATAL:content/browser/gpu/gpu_data_manager_impl_private.cc:416] GPU process isn't usable. Goodbye.
Perhaps this can solve your problem. Reinstall both firmwares.
sudo pacman -S linux-firmware-intel linux-firmware-amdgpu
If not installed Intel Compute Runtime
sudo pacman -S intel-compute-runtime
and switch from mesa to mesa-git (say yes to all, if ask)
pacseek mesa-git or paru -S mesa-git
after this pls reboot and test. Result = ?
Unfortunately, “reinstalling” isn’t really a thing on Linux. This is only “helpful” when there are pacman hooks involved that get triggered on a reinstallation or if there are corrupt files. Neither of which seems to be the case here.
The intel-compute-runtime is only useful for oneAPI or OpenCL.
May you try launching Rani like so:
garuda-rani --enable-logging --in-process-gpu
Also, regardless of outcome, may you share the output of:
DRI_PRIME=1 glxinfo; glxinfo
garuda-rani --enable-logging --in-process-gpu outputted:
fish: Job 1, 'garuda-rani --enable-logging --…' terminated by signal SIGBUS (Misaligned address error)
but did not get Rani to run.
DRI_PRIME=1 glxinfo; glxinfo output: outputOfDRI_PRIME=1 glxinfo; glxinfo - Pastebin.com
(outupt is waaaaaaay to large for a forum post) (If the link doesn’t work lmk and I’ll re-post)
ty again for the help so far!
This unfortunately doesn’t seem to be the full output. One of the commands appears to be missing.
Ok, I managed to get the full output this time! (I think)
DRI_PRIME=1 glxinfo; glxinfo:
ty!
Hmm, I’m still missing the output from the AMD GPU here for some reason.
  1. dgpu (intel) and 2. igpu (amd) it’s not default for me. (i read this for the first time)
Yeah, I’m not certain what’s up with that here. Both GPUs should be usable/active.
Ok, so I ran these commands a second time just now to see if I’d get a different output/what would happen:
terminal and file wise I got the same outputs as the first time but:
It seems like it lagged out my whole desktop environment: causing my Background and GUI to flicker black before returning to normal and the bottom menu to disappear completely. All of my inputs then began to lag severely (Like a 3-4 second delay on typing and mouse movements). a Reboot cleared this and returned functionality to normal. The web browser and YouTube video I was watching at that moment began to lag/drop frames as well, however the audio remained unaffected and continued to play normally.
Just thought this was notable.
https://www.asrock.com/MB/AMD/B650M%20Pro%20RS/index.asp#BIOS
Pls make a bios update first.
Think on the right settings after. AHCI mode / UEFI not CSM / Secure - Fast - Boot off /
Resize Bar enable.
As Info: the Intel B580 was released in Dez. 24 and important updates are in the new firmware.
What i don’t understand is that, that your igpu (cpu/gpu) is not device 1.
You have a option for the priority igpu <->dgpu in the bios, pls set this to igpu first.
Then test again. (my mind)
And if you don’t really need your igpu then disable the gpu in bios. (or only as test)
It ■■■■ing worked:
Updated my bios to latest version (3.30), disabled dGPU only mode and set my graphics preference to iGPU. Now Rani boots and I was able to menu navigate and everything!
Thank you all so much! bunch of lifesavers the lot of ya!
I’ll see if it holds on multiple boots before setting as solved, but it think we got it!
Yep it holds true.
Ladies and Gentlefolk
We gottem
