Hello. I have problem. Garuda Rani is just not running. If i try to open it using KDE - nothing. If i try to open it using console - nothing too… no any errors in logs. What i can do? I’ve used Arch-like distros before, but decided to try something more user-friendly. I use Mokka edition now.
The output from terminal of your garuda-inxi as required by the template is missing in your post!
Strange that there should be no feedback in the terminal either.
RANI is work in progress and you could try the git version instead.
sudo pacman -S garuda-rani-git
We had a similar case recently, but before we could find the cause, the OP had unfortunately reinstalled “Garuda Linux”:
If you have the same issue with garuda-rani-git, that might be helpful:
And if course, inxi missing. How are we supposed to troubleshoot this?
Hey, you’re a member of the Garuda team. You have to know everything without this fu*** inxi. So hurry and come up with something.
Whoever finds sarcasm in here can keep it…
I think I found the answer on another post of yours:
So instead of asking users to enter garuda-inxi in the terminal (which users seem to have an inate fear of), we use another alias.
Seems like everybody has no problem inputting anything to do with porn, so we change the alias to furry-porn and pipe the output to termbin. Bingo, Bango, Bongo, everyone and their dog will be posting their specs via the now excessively overused furry-porn command. Hopefully we’ll still be able to keep the forum up and running, as it it could end up being like a DDOS attack getting spammed with so many furry-porn outputs.
Just seems like nobody can resist porn, so the solution to the fear of the garudda-inxi command seems all too obvious.
Hmmm…
Hi,
I’m having the same issue where Garuda Rani will not open via the app icon or terminal. This has happened since installing Garuda Dr460nized Gaming for the first time this week. Any help is much appreciated.
I have this version installed: garuda-rani-git-2.5.1.r0.g397671d-1
Here’s my garuda-inxi output:
Kernel: 6.14.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=d0dc8817-cfe2-4d50-889a-3b4e7c8077d5 rw rootflags=subvol=@
Type: Laptop System: Alienware product: Alienware 13 R3 v: 1.8.0
Mobo: Alienware model: Alienware 13 R3 v: A00 serial: <superuser required>
part-nu: 0770 uuid: <superuser required> UEFI: Alienware v: 1.8.0
date: 05/28/2019
ID-1: BAT1 charge: 45.8 Wh (100.0%) condition: 45.8/76.0 Wh (60.3%)
volts: 17.3 min: 15.2 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3800 scaling: driver: intel_pstate
8: 800 bogomips: 44798
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:591b
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Dell
driver: nvidia v: 570.153.02 alternate: nouveau,nvidia_drm
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c20
Device-3: Realtek Integrated Webcam HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 0bda:58c2
display-ID: 0
Monitor-1: eDP-1 model: Samsung 0xa029 built: 2015 res: mode: 2560x1440
hz: 60 scale: 145% (1.45) to: 1766x993 dpi: 221 gamma: 1.2
size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
modes: 2560x1440
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 15.12 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 14 device: 0 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 25.1.1-arch1.2
device-ID: 8086:591b surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1060 driver: nvidia v: 570.153.02
device-ID: 10de:1c20 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Dell
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.14.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.4 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet driver: alx
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 3c:00.0
chip-ID: 1969:e0b1 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
vendor: Rivet Networks driver: ath10k_pci v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 168c:003e class-ID: 0280
temp: 29.0 C
IF: wlp61s0 state: up mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3
chip-ID: 0cf3:e300 class-ID: e001
Local Storage: total: 942.7 GiB used: 95.19 GiB (10.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 80003E00 temp: 32.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 17.97 GiB (18.0%)
fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 856.4 MiB size: 854.7 MiB (99.80%)
used: 620 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 17.97 GiB (18.0%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C pch: 40.5 C mobo: N/A
Memory: total: 16 GiB available: 15.48 GiB used: 4.31 GiB (27.8%)
Processes: 306 Power: uptime: 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1824 libs: 559 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-06-02
Last full system update: 2025-06-02
Unfortunately the live journal output is way too big to fit into the character limit of this post so I’ve only managed to include the first couple of lines. Let me know if there’s something in particular I should check for.
Jun 06 12:05:12 hostname systemd[3091]: Started Garuda Rani.
Jun 06 12:05:12 hostname garuda-rani[72383]: [2025-06-06][12:05:12][INFO][tauri::app] app::plugin::register; self=AppHandle { runtime_handle: WryHandle { context: Context { main_thread_id: ThreadId(1), proxy: EventLoopProxy { .. }, main_thread: DispatcherMainThreadContext { window_target: EventLoopWindowTarget { .. }, web_context: Mutex { data: {Some("/home/username/.local/share/org.garudalinux.rani"): WebContext { inner: WebContext { data_directory: Some("/home/username/.local/share/org.garudalinux.rani"), os: WebContextImpl { context: WebContext { inner: TypedObjectRef { inner: 0x56259e2bf710, type: WebKitWebContext } }, webview_uri_loader: WebViewUriLoader { lock: true, queue: Mutex { data: [], poisoned: false, .. } }, automation: false, app_info: None }, custom_protocols: {} }, referenced_by_webviews: {"main"}, registered_custom_protocols: {"ipc", "tauri"} }}, poisoned: false, .. }, windows: WindowsStore(RefCell { value: {WindowId(0): WindowWrapper { label: "main", inner: Some(Window { .. }) }} }), active_tracing_spans: ActiveTraceSpanStore(RefCell { value: [WindowDraw { id: WindowId(WindowId(1)), span: EnteredSpan { span: Span { name: "wry::window::draw", level: Level(Debug), target: "tauri_runtime_wry", disabled: true, module_path: "tauri_runtime_wry", line: 4199, file: "/home/builder/.cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tauri-runtime-wry-2.6.0/src/lib.rs" }, _not_send: PhantomNotSend { ghost: PhantomData<*mut ()> } } }] }) } } }, manager: AppManager { window: WindowManager { default_window_icon: Some(Image { rgba: [...], width: 32, height: 32 }) }, plugins: Mutex { data: PluginStore { plugins: ["prevent-default", "cli", "shell", "process", "os", "window-state", "store", "positioner", "notification", "http", "clipboard", "fs", "path", "event", "window", "webview", "app", "resources", "image", "menu", "tray", "__TAURI_CHANNEL__"] }, poisoned: false, .. }, state: StateManager { map: Mutex { data: {TypeId(0xa557f373208a66cd19f7fffcf87cd3e1): Any { .. }, TypeId(0xec097c75dc4515189b8cb943b767d1e7): Any { .. }, TypeId(0x00de6deaa568f577516c7e9d017e6968): Any { .. }, TypeId(0xca6d82b28d942c7cdccbc5ce6ea717a9): Any { .. }, TypeId(0x27b6e902fb911d26f153c37ebf5e988b): Any { .. }, TypeId(0x634269f765cdc09b6e14cac93a09270b): Any { .. }, TypeId(0xbf5f5148bcf0aa8677bae7e43417d2cd): Any { .. }, TypeId(0x3e90498a68f36088f60af88df10419cd): Any { .. }, TypeId(0x7f053291920a211da37380ad9c29c5cf): Any { .. }, TypeId(0xb7664eabd3d24d4bb9363ed83a3d612e): Any { .. }, TypeId(0xc32062187614678ea3f46816d792be14): Any { .. }, TypeId(0xa2f0adc8d0cc85193399b74a0cc9b655): Any { .. }, TypeId(0x3e6b11c325eab14093fbb90766250634): Any { .. }, TypeId(0x7ae43fa86ed612748bc41620bdb50c98): Any { .. }, TypeId(0x56260fd05a6a91c8df9d0d20ae1439fe): Any { .. }, TypeId(0xfd5df32c9de4fa3359ec5850debe163f): Any { .. }}, poisoned: false, .. } }, config: Config { schema: None, product_name: Some("garuda-rani"), main_binary_name: None, version: Some("2.2.0"), identifier: "org.garudalinux.rani", app: AppConfig { windows: [WindowConfig { label: "main", create: true, url: App("index.html"), user_agent: None, drag_drop_enabled: true, center: true, x: None, y: None, width: 1670.0, height: 710.0, min_width: Some(900.0), min_height: Some(600.0), max_width: None, max_height: None, prevent_overflow: None, resizable: true, maximizable: true, minimizable: true, closable: true, title: "Garuda Rani", fullscreen: false, focus: true, transparent: false, maximized: false, visible: false, decorations: false, always_on_bottom: false, always_on_top: false, visible_on_all_workspaces: false, content_protected: false, skip_taskbar: false, window_classname: None, theme: None, title_bar_style: Transparent, traffic_light_position: None, hidden_title: false, accept_first_mouse: false, tabbing_identifier: None, additional_browser_args: None, shadow: true, window_effects: None, incognito: false, parent: None, proxy_url: None, zoom_hotkeys_enabled: false, browser_extensions_enabled: false, use_https_scheme: false, devtools: None, background_color: None, background_throttling: None, javascript_disabled: false, allow_link_preview: true, disable_input_accessory_view: false }], security: SecurityConfig { csp: None, dev_csp: None, freeze_prototype: false, dangerous_disable_asset_csp_modification: Flag(false), asset_protocol: AssetProtocolConfig { scope: AllowedPaths([]), enable: false }, pattern: Brownfield, capabilities: [], headers: None }, tray_icon: None, macos_private_api: false, with_global_tauri: false, enable_gtk_app_id: true }, build: BuildConfig { runner: None, dev_url: Some(Url { scheme: "http", cannot_be_a_base: false, username: "", password: None, host: Some(Domain("localhost")), port: Some(1420), path: "/", query: None, fragment: None }), frontend_dist: Some(Directory("../dist/garuda-rani/browser")), before_dev_command: None, before_build_command: None, before_bundle_command: None, features: None, remove_unused_commands: false }, bundle: BundleConfig { active: true, targets: All, create_updater_artifacts: Bool(false), publisher: None, homepage: None, icon: ["icons/32x32.png", "icons/128x128.png", "icons/128x128@2x.png", "icons/icon.icns", "icons/icon.ico"], resources: None, copyright: None, license: None, license_file: None, category: None, file_associations: None, short_description: None, long_description: None, use_local_tools_dir: false, external_bin: None, windows: WindowsConfig { digest_algorithm: None, certificate_thumbprint: None, timestamp_url: None, tsp: false, webview_install_mode: DownloadBootstrapper { silent: true }, allow_downgrades: true, wix: None, nsis: None, sign_command: None }, linux: LinuxConfig { appimage: AppImageConfig { bundle_media_framework: false, files: {} }, deb: DebConfig { depends: None, recommends: None, provides: None, conflicts: None, replaces: None, files: {}, section: None, priority: None, changelog: None, desktop_template: None, pre_install_script: None, post_install_script: None, pre_remove_script: None, post_remove_script: None }, rpm: RpmConfig { depends: None, recommends: None, provides: None, conflicts: None, obsoletes: None, release: "1", epoch: 0, files: {}, desktop_template: None, pre_install_script: None, post_install_script: None, pre_remove_script: None, post_remove_script: None, compression: None } }, macos: MacConfig { frameworks: None, files: {}, bundle_version: None, minimum_system_version: Some("10.13"), exception_domain: None, signing_identity: None, hardened_runtime: true, provider_short_name: None, entitlements: None, dmg: DmgConfig { background: None, window_position: None, window_size: Size { width: 660, height: 400 }, app_position: Position { x: 180, y: 170 }, application_folder_position: Position { x: 480, y: 170 } } }, ios: IosConfig { template: None, frameworks: None, development_team: None, bundle_version: None, minimum_system_version: "13.0" }, android: AndroidConfig { min_sdk_version: 24, version_code: None } }, plugins: PluginConfig({"cli": Object {"args": Array [Object {"name": String("verbose"), "short": String("v")}], "description": String("Garuda Rani - Reliable Assistant for Native Installations"), "longDescription": String("The command-line interface for Garuda Rani, allowing you to perform various system management tasks directly from your terminal."), "subcommands": Object {"diagnostics": Object {"args": Array [Object {"description": String("Upload logs to PrivateBin"), "longDescription": String("Automatically uploads the collected diagnostic information to a PrivateBin instance."), "name": String("upload"), "short": String("u")}], "description": String("System debugging information and tools"), "longDescription": String("Allows you to quickly access and view various system logs and information for debugging purposes."), "subcommands": Object {"dmesg": Object {"description": String("View kernel logs (dmesg)"), "longDescription": String("Navigates to the diagnostics tab and displays the kernel ring buffer using 'dmesg'.")}, "full": Object {"description": String("Gather full diagnostics information"), "longDescription": String("Navigates to the diagnostics tab and initiates the display of comprehensive diagnostic information.")}, "inxi": Object {"description": String("Display common system information (inxi)"), "longDescription": String("Navigates to the diagnostics tab and displays the output of the 'inxi' command, providing a quick overview of your system.")}, "journalctl": Object {"description": String("View system logs (journalctl)"), "longDescription": String("Navigates to the diagnostics tab and displays the system journal logs using 'journalctl'.")}, "pacman": Object {"description": String("Show latest Pacman logs"), "longDescription": String("Navigates to the diagnostics tab and displays the recent logs from the Pacman package manager.")}, "systemctl": Object {"description": String("List system services (systemctl)"), "longDescription": String("Navigates to the diagnostics tab and displays the output of 'systemctl list-units', showing the status of system services.")}}}, "gaming": Object {"description": String("Gaming related tools and settings"), "longDescription": String("Provides quick access to various gaming-related applications and settings within Garuda Rani."), "subcommands": Object {"controllers": Object {"description": String("Controller support"), "longDescription": String("Navigates to the controller support settings tab.")}, "emulators": Object {"description": String("Emulators"), "longDescription": String("Navigates to the emulators tab.")}, "games": Object {"description": String("Installed games"), "longDescription": String("Navigates to the tab showing installed games (if applicable).")}, "launchers": Object {"description": String("Game launchers"), "longDescription": String("Navigates to the tab displaying installed game launchers.")}, "misc": Object {"description": String("Miscellaneous gaming utilities"), "longDescription": String("Navigates to the tab containing miscellaneous gaming utilities.")}, "tools": Object {"description": String("Gaming tools"), "longDescription": String("Navigates to the tab listing various gaming tools.")}, "wine": Object {"description": String("WINE settings"), "longDescription": String("Navigates to the WINE configuration tab.")}}}, "maintenance": Object {"description": String("System maintenance operations"), "longDescription": String("Provides tools for keeping your Garuda Linux system in a healthy state, including updating, cleaning, and resetting configurations."), "subcommands": Object {"common": Object {"description": String("Common maintenance tasks"), "longDescription": String("Executes frequently used maintenance tasks such as cleaning the package cache and removing orphaned packages.")}, "garuda-update": Object {"description": String("Garuda update related tools"), "longDescription": String("Provides access to specific Garuda Linux update utilities and rescue tools.")}, "reset": Object {"description": String("Reset system configurations"), "longDescription": String("Allows you to reset various system configurations to their default state, which can be helpful for troubleshooting.")}}}, "settings": Object {"description": String("Change the application settings"), "longDescription": String("Allows changing the applications own settings easily.")}, "system-tools": Object {"description": String("Application and system settings"), "longDescription": String("Opens or navigates to different sections of the Garuda Rani settings, allowing you to manage system components, core settings, packages, kernels, locales, and services."), "subcommands": Object {"components": Object {"description": String("Manage system components"), "longDescription": String("Navigates to the section where you can view and manage various system components and their status.")}, "kernels": Object {"description": String("Manage installed kernels"), "longDescription": String("Navigates to the kernel management settings.")}, "locales": Object {"description": String("Configure system locales"), "longDescription": String("Navigates to the locale configuration settings.")}, "packages": Object {"description": String("Manage installed packages"), "longDescription": String("Navigates to the package management section within the settings.")}, "services": Object {"description": String("Manage system services"), "longDescription": String("Navigates to the system services management interface.")}, "system": Object {"description": String("Configure core system settings"), "longDescription": String("Navigates to the area where you can adjust fundamental system settings.")}}}}}}) }, app_icon: None, package_info: PackageInfo { name: "garuda-rani", version: Version { major: 2, minor: 2, patch: 0 }, authors: "dr460nf1r3:TNE", description: "Garuda Rani", crate_name: "garuda-rani" }, pattern: Brownfield, tray: TrayManager { icon: None } }, event_loop: Mutex { data: EventLoop { main_thread_id: ThreadId(1) }, poisoned: false, .. } } name="autostart"
Thanks,
Chris
