Garuda-Rani common info issue
╭─gampel@garudacomp in ~
🕙 11:42:15
╰─λ garuda-inxi
Kernel: 6.16.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc avail: hpet,acpi_pm parameters: quiet
initcall_blacklist=simpledrm_platform_driver_init loglevel=3 ibt=off
root=UUID=fd644241-2723-4347-b0fc-747c588e12fa rw rootflags=subvol=@
initrd=@\boot\initramfs-linux-zen.img
Type: Desktop System: Micro-Star product: MS-7D54 v: 2.0
Mobo: Micro-Star model: MAG X570S TORPEDO MAX (MS-7D54) v: 2.0
Megatrends LLC. v: A.C0 date: 09/03/2025
Device-1: hidpp_battery_0 model: Logitech Wireless Illuminated Keyboard K800
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701035
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3758 min/max: 558/4208 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3758 2: 3758 3: 3758
4: 3758 5: 3758 6: 3758 7: 3758 8: 3758 9: 3758 10: 3758 11: 3758 12: 3758
bogomips: 86399
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
bus-ID: 2f:00.0 chip-ID: 1002:73ff class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung C32F39M serial: <filter> built: 2019
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 20.1.8 DRM 3.64 6.16.7-zen1-1-zen) device-ID: 1002:73ff
API: Vulkan v: 1.4.321 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.2.3-arch1.2
device-ID: 1002:73ff surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM
de: kscreen-console,kscreen-doctor gpu: amd-smi, amdgpu_top, corectrl, lact
bus-ID: 2f:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
Device-4: Razer USA Kraken Tournament Edition
lanes: 1 mode: 1.1 bus-ID: 3-6.1:4 chip-ID: 1532:0520 class-ID: 0300
API: ALSA v: k6.16.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
lanes: 1 port: d000 bus-ID: 28:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 4.66 TiB used: 1.91 TiB (41.0%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
model: WDS500G1XHE-00AFY0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 615400WD temp: 39.9 C scheme: GPT
model: WD30EZAX-00C8UB0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: SP900 size: 119.24 GiB
serial: <filter> fw-rev: 2a scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 500GB
used: 200.94 GiB (43.2%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 332 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
Kernel: swappiness: 180 (default 60) cache-pressure: 100 (default) zswap: no
dev: /dev/nvme1n1p3 maj-min: 259:8
System Temperatures: cpu: 34.0 C mobo: 32.0 C gpu: amdgpu temp: 31.0 C
mem: 32.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 892 fan-3: 0 fan-4: 895 fan-5: 870
fan-6: 0 fan-7: 0 gpu: amdgpu fan: 891
Memory: total: 32 GiB available: 31.26 GiB used: 5.77 GiB (18.5%)
Processes: 413 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 258 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 2134 libs: 568 tools: octopi,pacseek,paru,yay
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish
v: 4.0.8 running-in: konsole inxi: 3.3.39
Garuda (2.8.3-2):
System install date:     2024-08-07
Last full system update: 2025-09-20
23/24 checks run in 0.84 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
╭─gampel@garudacomp in ~ took 2s
🕙 11:42:24
Over Garuda-Rani, on my system, garuda-inxi is failing. All other log information works fine.
╭─gampel@garudacomp in ~ took 2m19s
🕙 11:39:52
╰─λ garuda-rani -d
(electron:157573): LIBDBUSMENU-GLIB-WARNING **: 11:39:59.318: About to Show called on an item wihtout submenus.  We're ignoring it.
(electron:157573): LIBDBUSMENU-GLIB-WARNING **: 11:39:59.328: About to Show called on an item wihtout submenus.  We're ignoring it.
INFO [11:39:59.152]: Renderer - Loaded 7 settings from store
INFO [11:39:59.516]: Renderer - Last update: 2025-09-20T09:28:54.000Z
INFO [11:40:00.103]: Renderer - No aur updates available
INFO [11:40:00.446]: Renderer - No updates available
ERROR [11:40:06.715]: Renderer - Error collecting output:
[157610:0920/114009.724916:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 1 times!
[157610:0920/114254.641182:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 2 times!
[157610:0920/114304.400757:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 3 times!
Current, i have installed the git version.
complete log
Same here.
  Kernel: 6.17.0-rc6-1-mainline-x64v3 arch: x86_64 bits: 64 compiler: gcc
    v: 15.2.1 clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline-x64v3
    root=UUID=4fc9ad06-65d5-4c70-bb01-ba0992e31abd rw rootflags=subvol=@
    quiet loglevel=3
    GRUB_BTRFS_SNAPSHOT_KERNEL_PARAMETERS=rd.live.overlay.overlayfs=1
  Type: Desktop Mobo: ASUSTeK model: TUF B450-PLUS GAMING v: Rev X.0x
    UEFI: American Megatrends v: 4622 date: 09/29/2024
  Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
    gen: 1+ level: v3 note: check built: 2018-21 process: GF 12nm
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1273 min/max: 1550/3400 boost: enabled
    base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 1273 2: 1273 3: 1273 4: 1273
    5: 1273 6: 1273 7: 1273 8: 1273 9: 1273 10: 1273 11: 1273 12: 1273
    bogomips: 81603
    ssse3 svm
    XT/6600M] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
    speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
    Writeback-1 bus-ID: 0b:00.0 chip-ID: 1002:73ff class-ID: 0300
    compositor: kwin_wayland driver: gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: Idek Iiyama PL3271Q serial: <filter> built: 2023
    res: mode: 2560x1440 hz: 165 scale: 90% (0.9) to: 2844x1600 dpi: 93
    gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9
    modes: max: 2560x1440 min: 720x400
    LLVM 20.1.8 DRM 3.64 6.17.0-rc6-1-mainline-x64v3) device-ID: 1002:73ff
    memory: 7.81 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.321 layers: 6 device: 0 type: discrete-gpu name: AMD
    de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
    bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
    bus-ID: 0d:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Razer USA Kraken Tournament Edition
    lanes: 1 mode: 1.1 bus-ID: 1-7.2:5 chip-ID: 1532:0520 class-ID: 0300
  API: ALSA v: k6.17.0-rc6-1-mainline-x64v3 status: kernel-api tools: N/A
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
  Local Storage: total: 3.33 TiB used: 168.01 GiB (4.9%)
    fw-rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
  SMART: yes health: PASSED on: 51d 9h cycles: 2,451
    read-units: 54,277,803 [27.7 TB] written-units: 23,232,776 [11.8 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
    family: based SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 2B6Q temp: 27 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 290d 17h cycles: 2912
    written: 5.46 TiB
    model: WD1600BEKT-00PVMT0 family: Scorpio Black size: 149.05 GiB block-size:
    physical: 512 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 28 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 1y 168d 23h cycles: 4814
    Old-Age: UDMA CRC errors: 668 alert: Bad cable/connection?
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST31000528AS
    family: Barracuda 7200.12 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: CC46 temp: 33 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 342d 3h cycles: 11272
    read: 1.98 TiB written: 785.3 GiB Pre-Fail: attribute: Spin_Retry_Count
  ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST31000524AS
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: JC45 temp: 31 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 54d 7h cycles: 1868
    read: 802.6 GiB written: 1.39 TiB Pre-Fail: attribute: Spin_Retry_Count
  ID-1: / raw-size: 931.22 GiB size: 831.22 GiB (89.26%)
    used: 168.01 GiB (20.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 931.22 GiB size: 831.22 GiB (89.26%)
  ID-4: /var/log raw-size: 931.22 GiB size: 831.22 GiB (89.26%)
  ID-5: /var/tmp raw-size: 931.22 GiB size: 831.22 GiB (89.26%)
  ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 51.1 C mobo: 23.0 C gpu: amdgpu temp: 57.0 C
    mem: 62.0 C
  Fan Speeds (rpm): cpu: 1225 fan-2: 0 fan-3: 960 fan-4: 757 fan-6: 0
    gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.25 gpu: amdgpu watts: 16.00
  Memory: total: 16 GiB available: 15.52 GiB used: 4.78 GiB (30.8%)
  Processes: 436 Power: uptime: 2h 30m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1854 libs: 518 tools: octopi,paru Compilers:
    clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 running-in: konsole
    inxi: 3.3.39
Garuda (2.8.3-2):
  System install date:     2025-08-15
  Garuda release:          250801
23/24 checks run in 1.05 seconds ⌛
--- LOW ---
After a cup of days, here, no answer.
As Info: Git uninstalled default rani installed.
the same:
🕙 16:09:43
╰─λ garuda-rani  (with settings debug)
DEBUG [17:07:38.833]: Renderer - Loading off
DEBUG [17:07:40.121]: Renderer - Diagnostics component initialized
DEBUG [17:07:40.123]: Renderer - Terminal theme switched via effect
DEBUG [17:07:41.520]: Renderer - Getting output for inxi
DEBUG [17:07:41.520]: Renderer - Loading on
DEBUG [17:07:41.520]: Renderer - Executing bash code: garuda-inxi
DEBUG [17:07:41.520]: Renderer - Executing one-off command: bash ["--norc","--noprofile","-c","LANG=C garuda-inxi"]
DEBUG [17:07:43.995]: Renderer - One-off command bash finished with code: 1
ERROR [17:07:43.995]: Renderer - Error collecting output:
DEBUG [17:07:43.995]: Renderer - Done getting output for inxi
DEBUG [17:07:43.995]: Renderer - Loading off
DEBUG [17:07:45.038]: Renderer - Getting output for systemd-analyze
DEBUG [17:07:45.038]: Renderer - Loading on
DEBUG [17:07:45.038]: Renderer - Executing bash code: systemd-analyze blame --no-pager && systemd-analyze critical-chain --no-pager
DEBUG [17:07:45.038]: Renderer - Executing one-off command: bash ["--norc","--noprofile","-c","LANG=C systemd-analyze blame --no-pager && systemd-analyze critical-chain --no-pager"]
DEBUG [17:07:46.385]: Renderer - One-off command bash finished with code: 0
DEBUG [17:07:46.386]: Renderer - Writing to clear terminal and buffer
DEBUG [17:07:46.386]: Renderer - Writing to clipboard
DEBUG [17:07:46.392]: Renderer - Done getting output for systemd-analyze
DEBUG [17:07:46.393]: Renderer - Loading off
[720682:0929/170749.399656:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 1 times!
[720682:0929/170913.389259:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 2 times!
[720682:0929/170931.409301:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 3 times!
DEBUG [17:09:41.024]: Main - Window is closing, saving bounds...
DEBUG [17:09:41.036]: Renderer - All event listeners removed
Sorry, I missed this as I was in vacation until a while ago and just found it again.
This should in theory already be fixed (side effect of a change TNE made a few days ago), as I see it the problem was garuda-inxi exiting with a non-zero exit code due to garuda-health finding an issue. Since this always exits with 0 now, it should work as expected even with recognized issues.
In case I miss something again for while regarding Rani feel free to @ me in the future :waving_hand:
Nothing to sorry about. I hope you had a nice and relaxing vacation.
It´s working here now as expected. Thank you for fixing :+1:
Not allowed and was not approved. :upside_down_face:
Me too, it was relaxed. :slightly_smiling_face:
