Garuda Rani always loade on system oot/reboot
I just installed Garuda-KDE-Lite on my older Dell Inspiron 5555 laptop PC, dual-booting with Windows 11, and Garuda Rani loads every time I boot/reboot the computer into Garuda. I can’t find an option to stop this behavior. Any help will be greatly appreciated.
Garuda-inxi:
  Kernel: 6.14.4-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: root=UUID=58b7460c-20c2-4225-94a2-c68fcd14d5d9 rw
    rootflags=subvol=@ quiet loglevel=3 ibt=off
    initrd=@\boot\initramfs-linux-zen.img
  Type: Portable System: Dell product: Inspiron 5555 v: A12
    serial: <superuser required> Chassis: type: 8 v: A12
  Mobo: Dell model: 08C2X1 v: A00 serial: <superuser required>
    part-nu: Inspiron 5555 uuid: <superuser required> UEFI: Dell v: A12
    date: 08/30/2016
  ID-1: BAT1 charge: 37.4 Wh (98.7%) condition: 37.9/41.4 Wh (91.4%)
    volts: 16.4 min: 14.8 model: SDI DELL 07G07597597 type: Li-ion
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525
  Info: model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
    arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
    model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
  Speed (MHz): avg: 998 min/max: 1000/2200 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 998 2: 998 3: 998 4: 998
    bogomips: 17568
  Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics]
    vendor: Dell driver: radeon v: kernel alternate: amdgpu arch: GCN-2
    code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9851
  Device-2: Suyin Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 064e:920b
    compositor: kwin_wayland driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x5441 built: 2015 res: mode: 1366x768
    hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
  API: OpenGL v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1 glx-v: 1.4
    direct-render: yes renderer: KABINI (radeonsi ACO DRM 2.50
    6.14.4-zen1-2-zen) device-ID: 1002:9851 memory: 1000 MiB unified: no
    display-ID: :0.0
  API: Vulkan v: 1.4.309 layers: 5 device: 0 type: cpu name: llvmpipe (LLVM
    19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.5-arch1.1 (LLVM 19.1.7)
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
  Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
  API: ALSA v: k6.14.4-zen1-2-zen status: kernel-api tools: N/A
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
    vendor: Dell Vostro 3470 driver: ath9k v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
  Device-2: Realtek 802.11ac NIC driver: rtl8821cu type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:c811
  IF: wlp0s16u1 state: up mac: <filter>
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.1:4 chip-ID: 0cf3:e005
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: not found
    rfk-block: hardware: no software: no address: see --recommends
  Local Storage: total: 1.39 TiB used: 9.18 GiB (0.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
    model: SPCC Solid State Disk size: 953.87 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 8A0
    model: WD5000AAKX-00ERMA0 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
    tech: N/A serial: <filter> fw-rev: 0104 scheme: MBR
  ID-1: / raw-size: 40 GiB size: 40 GiB (100.00%) used: 8.12 GiB (20.3%)
    fs: btrfs dev: /dev/sda6 maj-min: 8:6
    used: 36.7 MiB (3.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 428.43 GiB size: 428.43 GiB (100.00%)
    used: 1.03 GiB (0.2%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
  ID-4: /var/log raw-size: 40 GiB size: 40 GiB (100.00%)
    used: 8.12 GiB (20.3%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
  ID-5: /var/tmp raw-size: 40 GiB size: 40 GiB (100.00%)
  ID-1: swap-1 type: zram size: 14.56 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
  ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda5 maj-min: 8:5
  System Temperatures: cpu: 49.0 C mobo: 39.0 C sodimm: 35.0 C gpu: radeon
    temp: 54.0 C
  Memory: total: 16 GiB note: est. available: 14.56 GiB used: 1.96 GiB (13.4%)
  Processes: 221 Power: uptime: 29m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.8 GiB services: org_kde_powerdevil,upowerd
  Packages: pm: pacman pkgs: 1216 libs: 383 tools: pamac pm: flatpak pkgs: 0
    Compilers: gcc: 15.1.1 Shell: garuda-inxi default: Bash v: 5.2.37
  System install date:     2025-05-04
  Last full system update: 2025-05-04 ↻
ernie
Inside the forum you find the solution
  • disable the autostart (plasma system-settings)
  • Garuda Rani → App settings → disable “Auto-start application”.
  • perhaps you have ./config/autostart → delete the rani entries
  • and think on this, if you have “session-restore” enabled in the settings exclude rani there,too. (if it´s running)
Thank you! It never occurred to me that Garuda Rani would be set to auto-start in .config/autostart My issue is solved!
Ernie
