Garuda power save tweaks and amd cpus
Hello there folks,
i was wondering if something is just broken with the power save tweaks or the corresponding settings in GSM. Im asking since i started using this notebook recently again and wanted to increase battery life since i am not doing anything really intensive on it. But from what i can see the power-profiles-daemon just kinda doesn't work completely, since the gui bar in the battery icon menu seems to be missing. I think setting the profile via commandline (at least in power-saver mode) seems to work just fine. I of course expected the undervolting and thermald program to not work but is there any way to verify if the cpu-autofreq(or powerprofiles) is working as it should?
Im kinda new to this perticular topic, so if you have any more tips id appreciate that.
Thanks for the help in advance.
 ╭─[email protected] in ~
 ╰─λ garuda-inxi
  Kernel: 6.1.27-1-lts arch: x86_64 bits: 64 compiler: gcc
    v: 13.1.1 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
    root=UUID=6eb84ae1-4b94-4143-a6a6-8ed3e24b92bf rw
    [email protected] quiet
    resume=UUID=5146f49c-6eec-42cc-bc40-7556fe544429
    loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
  Type: Convertible System: HP
    product: HP ProBook x360 435 G7 v: N/A
    serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 8735 v: KBC Version 09.24.00
    serial: <superuser required> UEFI: HP v: S80 Ver. 01.04.02
    date: 01/18/2021
  ID-1: BAT0 charge: 16.4 Wh (58.4%)
    condition: 28.1/45.0 Wh (62.4%) volts: 12.9 min: 11.4
    model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: charging cycles: 211
  Device-1: hid-0018:04F3:2AD3.0002-battery
    model: ELAN2513:00 04F3:2AD3 serial: N/A charge: N/A
    status: N/A
  Info: model: AMD Ryzen 3 4300U with Radeon Graphics
    bits: 64 type: MCP arch: Zen 2 gen: 3 level: v3 note: check
    built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache:
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB
    desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1399 high: 1400 min/max: 1400/2700
    boost: enabled scaling: driver: acpi-cpufreq
    governor: powersave cores: 1: 1400 2: 1400 3: 1400
    4: 1397 bogomips: 21570
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2
    sse4a ssse3 svm
  Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu
    v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
    temp: 35.0 C
  Device-2: Quanta HP HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
    chip-ID: 0408:5375 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.8
    compositor: kwin_x11 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0848
    built: 2018 res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2
    size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon
    Graphics (renoir LLVM 15.0.7 DRM 3.49 6.1.27-1-lts)
    direct-render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Hewlett-Packard driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
  API: ALSA v: k6.1.27-1-lts status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.70 status: active with:
    1: pipewire-pulse status: active 2: wireplumber
    status: active 3: pipewire-alsa type: plugin 4: pw-jack
    type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
    chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 1-3:2 chip-ID: 8087:0029 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: up
    address: see --recommends
  Local Storage: total: 238.47 GiB used: 50.95 GiB (21.4%)
  SMART Message: Required tool smartctl not installed.
    Check --recommends
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG40ZNV256G KIOXIA size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: HP00AE00 temp: 32.9 C
  ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
    used: 30.71 GiB (62.9%) fs: btrfs dev: /dev/nvme0n1p4
    maj-min: 259:4
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 181.34 GiB
    size: 181.34 GiB (100.00%) used: 20.24 GiB (11.2%)
  ID-4: /var/log raw-size: 48.83 GiB
    size: 48.83 GiB (100.00%) used: 30.71 GiB (62.9%) fs: btrfs
  ID-5: /var/tmp raw-size: 48.83 GiB
  Kernel: swappiness: 133 (default 60)
    cache-pressure: 100 (default)
  ID-1: swap-1 type: zram size: 7.17 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: partition size: 7.81 GiB
    used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
    maj-min: 259:2
  System Temperatures: cpu: 36.4 C mobo: N/A gpu: amdgpu
    temp: 36.0 C
  Processes: 245 Uptime: 1h 47m wakeups: 4 Memory:
  available: 7.17 GiB used: 3.09 GiB (43.1%) Init: systemd
  v: 253 default: graphical tool: systemctl Compilers:
  gcc: 13.1.1 Packages: pm: pacman pkgs: 1247 libs: 391
  tools: yay Shell: fish v: 3.6.1 running-in: alacritty
  inxi: 3.3.27
  System install date:     2022-12-31
  Last full system update: 2023-05-17
