Garuda-OS, xfce - no boot Option - TILT-System
Hello Garuda Community
I have a problem.
The boot process is canceled - in short: Cannot boot the
cannot boot the system.
I get the following information on the display:
I am currently asking myself - What is the cause of this TILT ?
I have been using Linux systems for over 20 years and rarely have any
distributions crashed ?
I first tried with “ recovery mode )
Tried several variants -
Result: unsuccessful ?
I did an update before and shut down the computer.
6 hours later I wanted to use the system - no booting possible.
How can it be that a running system crashes ?
thank you, best regards
Did you switch kernels?
What about your snapshots or fallback systems?, did you use any?
Check /etc/fstab for the UUID in picture.
New hard drive installed.
Try to boot from BIOS with correct drive, check with
lsblk -f
First try last working
no, …no kernel-update,
standard-update, with " pacman -Syu "
Standard is
upd
update
garuda-update
[quote=“SGS, post:3, topic:39175”]
Try to boot from BIOS with correct drive, check with [/quote]
No, not a new hard disk.
The memory has been in use for approx. 1 year =
Crucial, sata, 2.5”, - no problems
I only have the hard disk + Garuda OS from a
defective
computer ( Lenoxo X240 , with defective usb port -
probably cold solder joints and keyboard defect ) into a Lenovo T450
rebuilt.
Had worked for 3 weeks without any problems, as already with
X times other distributions = SSD change in other hardware -
use a removable frame on the PC desktop with 1 x 2.5” Windows 10 OS +
a SATA SSD with Linux in alternation -
also works in the Lenovos when I rebuild )
Possible,
that the hardware change could be a problem ? But not for me
understandable,
if the computer with Garuda OS works for 3 - 4 weeks without any problems
worked -
Nothing was missing - updates made and just worked with it -
I just wonder - how can it be that the system is so capitalized?
crashes ,
so that nothing works anymore?
[quote="SGS, post:3, topic:39175"]
[/quote]
can no longer test anything.
Can access system data with external controller
system data,
on a replacement computer or desktop computer -
But I am only a user and
have no plan,
how to install the boot loader )
partition a partition with gparted - no problem
but in the system there
fiddling around ?
Honestly, ...I have too little idea.  I use over 20
years of Linux distributions,
but this crash is the over-kill for me ....where I no longer
get any further.
I've had a case like this before with Garuda, but with System
reboot again -
But I've only had similar phenomena under AntergOS so far.
and manjaro.
AntergOS was discontinued - unfortunately - after 5 years of use -
with Manjaro I had several system crashes, which is why
then switched to
Garuda ( Endovour-OS did not appeal to me )
But I've never had such problems with buntu, debian derivatives.
Could possibly be a Garuda system error ?
What exactly is the cause - I can not analyze now -
I will reinstall the system and then observe again ?
Thank you very much
best regards
Use live ISO, chroot (in welcome app), try to upd.
Maybe the upadate was in action as you shutdown the system.
Use live ISO, chroot (in the welcome app), try to update.
Maybe the update was in action when you shut down the system.
Thank you very much - That would be a solution - I have already tried with a
already tried to boot with another live USB OS -
but unfortunately unsuccessful
That would be possible that the update process has been interrupted.
has been interrupted -
I’ll have to be more careful next time
Very good tip - (I had carried out an update -)
and then the computer
shut down )
That could have been the cause, probably
Thank you very much
best regards
ps. werde mal neu installieren und beobachten
