I have Old Laptop the information about the PC is given below. I mostly use 2 to 3 application simultaneously. The other applications stuck in between, i checked the htop and the stats are as shown below. Just 2 to 3 application and the CPU consumption is almost 100%. any other ways to solve this. Like identifying and removing the unnecessary process or programs running in background or something? Previously i can run this many applications on windows 10 smoothly but in garuda linux the system hangs too much.
System Information
System: Kernel: 5.13.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2c3e9637-10ef-4bc0-90bb-0b245dbe8da9 rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Dell product: Latitude E6420 v: 01 serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: N/A serial: <filter> BIOS: Dell v: A14 date: 07/11/2012
Battery: ID-1: BAT0 charge: 18.0 Wh (39.0%) condition: 46.2/62.2 Wh (74.3%) volts: 11.0 min: 11.1 model: Sanyo DELL NH6K98C
type: Li-ion serial: <filter> status: Discharging
CPU: Info: Dual Core model: Intel Core i5-2520M bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19955
Speed: 798 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: Ricoh Laptop_Integrated_Webcam_FHD type: USB driver: uvcvideo bus-ID: 1-1.5:3 chip-ID: 05ca:181c
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 131 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: kernel port: 4080 bus-ID: 00:19.0
chip-ID: 8086:1502 class-ID: 0200
Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell Inspiron M5010 / XPS 8300 driver: wl
v: kernel modules: bcma port: 4040 bus-ID: 02:00.0 chip-ID: 14e4:4727 class-ID: 0280
IF-ID-1: wwp0s29u1u6i6 state: down mac: <filter>
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4060 bus-ID: 00:1f.2
chip-ID: 8086.282a rev: 04 class-ID: 0104
Drives: Local Storage: total: 223.57 GiB used: 51.95 GiB (23.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: B1D1 scheme: MBR
Partition: ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 51.95 GiB (23.2%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 51.95 GiB (23.2%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 51.95 GiB (23.2%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 51.95 GiB (23.2%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-1: swap-1 type: zram size: 5.68 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 56.0 C mobo: 27.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2870
Info: Processes: 202 Uptime: 2m wakeups: 2 Memory: 5.68 GiB used: 1.66 GiB (29.3%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1208 lib: 301 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
