Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=7ba56de5-0484-474e-8688-a6c4e02ebf0e rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: LENOVO product: 82JU v: Legion 5 15ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 15ACH6H
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: GKCN53WW date: 02/25/2022
ID-1: BAT0 charge: 55.4 Wh (100.0%) condition: 55.4/60.0 Wh (92.3%)
volts: 17.1 min: 15.4 model: SMP L20M4PC0 type: Li-poly serial: <filter>
status: full cycles: 87
Device-1: sony_controller_battery_40:1b:5f:fb:1f:92 model: N/A
serial: N/A charge: N/A status: full
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1770 high: 2720 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1771 2: 1397
3: 1395 4: 1397 5: 2480 6: 2320 7: 1397 8: 2720 9: 1726 10: 1565 11: 1396
12: 1397 13: 2100 14: 1791 15: 2082 16: 1396 bogomips: 102211
STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2560
Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
active: eDP-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1638
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:4 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: amdgpu
Monitor-1: DP-1-2 size-res: N/A modes: N/A
Monitor-2: eDP pos: primary res: 1920x1080 hz: 165 dpi: 142
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.9-zen1-1-zen)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: bus-ID: 1-1.1.4:35 gen: 3 chip-ID: 17ef:a022 class-ID: 0300
speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
Device-4: Lenovo Monitor USB Speaker type: USB
Device-5: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid bus-ID: 1-1.3:34 chip-ID: 054c:09cc
Device-6: Kingston HyperX Cloud Flight S type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.1:6 chip-ID: 0951:16ea
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
bus-ID: 3-4:4 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Local Storage: total: 1.98 TiB used: 23.64 GiB (1.2%)
model: PC SN730 SDBPNTY-1T00-1101 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11170001 temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
serial: <filter> rev: 11170001 temp: 40.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB model: General USB Flash Disk
size: 116.06 GiB block-size: physical: 512 B logical: 512 B type: SSD
used: 23.64 GiB (2.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 27.27 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 353 Uptime: 12m wakeups: 7 Memory: 27.27 GiB
used: 2.55 GiB (9.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1817
lib: 541 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-07-06
Last full system update: 2022-07-06
Hello, I'm new to Garuda obviously haha, I'm trying to connect to my monitor through display port, the monitor is a Legion Y44w-10. The monitor also acts as a USB HUB, the devices connected through the monitor work just fine, but I have no display output, any help you can provide would be greatly appreciated thanks!
