Hello everyone :),
Hey I am trying to use the garuda nix subsystem , but the instillation is failing.
After running
garuda-nix-subsytem install
I get the error
mount: /dev/binderfs: unknown filesystem type 'binder'.
dmesg(1) may have more information after failed mount system call.
mount: (hint) your fstab has been modified, but systemd still uses
the old version; use 'systemctl daemon-reload' to reload.
Kernel: 6.6.11-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm parameters: pti=on page_alloc.shuffle=1
BOOT_IMAGE=/@/boot/vmlinuz-linux-hardened root=UUID=5cdaaea7-2d12-4fc9-8004-fda5bae9be22 rw
rootflags=subvol=@ quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: Hyprland info: waybar vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM
Type: Laptop System: Hewlett-Packard product: HP EliteBook 840 G2 v: A3009D510203
Mobo: Hewlett-Packard model: 2216 v: KBC Version 96.56 serial: <superuser required>
UEFI: Hewlett-Packard v: M71 Ver. 01.09 date: 09/01/2015
ID-1: BAT0 charge: 15.6 Wh (80.8%) condition: 19.3/19.3 Wh (100.0%) volts: 13.0 min: 11.4
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: charging
Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
microcode: 0x2F
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2694 min/max: 500/2900 scaling: driver: intel_cpufreq governor: schedutil
cores: 1: 2694 2: 2694 3: 2694 4: 2694 bogomips: 18361
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard ZBook 15u G2 Mobile Workstation
driver: i915 v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP EliteBook integrated HD Webcam
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-7:5
chip-ID: 05c8:0374 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 compositor: Hyprland
driver: X: loaded: modesetting unloaded: vesa alternate: fbdev,intel dri: iris gpu: i915
display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0x233e built: 2012 res: 1600x900 dpi: 132 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes: 1600x900
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast
surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2) device-ID: 8086:1616
memory: 11.3 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 9 device: 0 type: integrated-gpu name: Intel HD Graphics 5500
(BDW GT2) driver: mesa intel v: 23.3.3-arch1.1 device-ID: 8086:1616 surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.3.3-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.6.11-hardened1-1-hardened status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: 5080
bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
IF: enp0s25 state: down mac
: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:3 chip-ID: 8087:0a2a class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 7 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
discoverable: yes pairing: yes class-ID: 6c010c
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060
bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 667.05 GiB (71.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
fw-rev: RSM7 scheme: GPT
ID-1: / raw-size: 491.68 GiB size: 491.68 GiB (100.00%) used: 377.09 GiB (76.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 296 KiB (0.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 491.68 GiB size: 491.68 GiB (100.00%) used: 377.09 GiB (76.7%) fs: btrfs
ID-4: /var/log raw-size: 491.68 GiB size: 491.68 GiB (100.00%) used: 377.09 GiB (76.7%)
ID-5: /var/tmp raw-size: 491.68 GiB size: 491.68 GiB (100.00%) used: 377.09 GiB (76.7%)
ID-1: swap-1 type: zram size: 11.57 GiB used: 377.9 MiB (3.2%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 268 Uptime: 21h 42m wakeups: 6 Memory: total: 12 GiB available: 11.57 GiB
used: 5.93 GiB (51.2%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: 2564 pm: pacman pkgs: 2538 libs: 521
tools: aura,pamac,paru,yay pm: flatpak pkgs: 14 pm: snap pkgs: 12 Client: shell wrapper
v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2022-01-22
Last full system update: 2024-01-15
Failed units: archlinux-keyring-wkd-sync.service systemd-networkd-wait-online.service
I have had issues before with /dev/binderfs ....so I need some assistance... First time trying nix,..
